deepNdirt
I would not use rebar. It is not designed for these type loads and not all rebar can be welded without reducing its strength in the heat affected zone (area near the weld subject to high temp).
Buy quality D-rings that are made to be welded on, and size them for the heaviest load you can but on the trailer, not the load you plan to carry today. Why limit your capacity in the future by saving a couple dollars now.
At a place I worked a while back we had some concrete barriers that had been poured with pieces of bent rebar protruding from the top so they could be lifted with a crane. During one rigging operation one of the loops broke. It snapped of like a twig. It had been loaded at an angle using a pair of slings instead of using a spreader and slings dropping straight down. That angular load was enough on the #6 bar (3/4" dia) to break it.
If you used rebar to make rigging attachment points on your trailer it would amount to the same setup...an angular load that could result in a break during transit, especially if the rigging was shock loaded as when making a quick stop or hitting a good size bump or pothole in the road.
But will they torque those bolts to the recommended value or will they over-tighten them..or just as bad... not tight enough. Will they use hardened washers or none at all. And where or what will they attach them to, that 3/16" thick web of the 4" channel or some flimsy angle iron that the bolts (w/o washers) could rip right through?
I agree that you need a decent welder (person) to install the rings. A trip to a weld shop might be cheap insurance.
Well scrub the rebar idea
