Does my new 2520 have too much antifreeze?
   / Does my new 2520 have too much antifreeze? #11
Ethylene glycol will burn if not mixed with water. I am using 5o-50 Peak premix formula, it is foolproof. When I used the unmixed version, I used distilled water to help with the life, but always mixed heavy on coolant side?60-40, but pockets of air cause havoc with in- block mixxing. No coolant and water pump seals can leak?
Car Doc,
Here is a refractometer, but it is only good to -60, and I'm pretty sure I'm at that point or below.
[ame=http://www.amazon.com/Robinair-75240-Coolant-Battery-Refractometer/dp/B000HTNODE]Amazon.com: Robinair 75240 Coolant and Battery Refractometer: Automotive[/ame]
   / Does my new 2520 have too much antifreeze? #14
Car Doc,
That's a real good one Danny and a bargain at that price I am not kidding!!!
Its the same exact one I have that I got from Snap-On and paid $120 or so for years ago. And btw its -60 for Propylene glycol and -84 for Ethylene glycol which is most likely what you are using it reads both plus battery specific gravity . hth :thumbsup:
What I like about refractometers is you can test them by putting a drop of tap water on the lens, they say use inoized or distilled it doesn't matter they all freeze the same but it will show you it works its a very accurate tool.
   / Does my new 2520 have too much antifreeze? #15
I'd rather have too much antifreeze and not freeze it. If you go 50/50 you could freeze it and destroy the engine.
   / Does my new 2520 have too much antifreeze? #16
??? 50:50 is the ratio engine manufacturers want.....safest to run
   / Does my new 2520 have too much antifreeze? #17
Yes thats correct and there are several reasons that support using no more than 50/50 however it will freeze so one ratio doesn't fit all areas so if it doesn't get below -34 where we are than 50/50 is ok.
   / Does my new 2520 have too much antifreeze? #18
Snowmobile manufacturers recommend a 60/40 ratio of ethylene glycol to distilled water and these things are subjected to extreme conditions ;)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
