Does my new 2520 have too much antifreeze?
   / Does my new 2520 have too much antifreeze? #11
Ethylene glycol will burn if not mixed with water. I am using 5o-50 Peak premix formula, it is foolproof. When I used the unmixed version, I used distilled water to help with the life, but always mixed heavy on coolant side?60-40, but pockets of air cause havoc with in- block mixxing. No coolant and water pump seals can leak?
Car Doc,
Here is a refractometer, but it is only good to -60, and I'm pretty sure I'm at that point or below.
[ame=http://www.amazon.com/Robinair-75240-Coolant-Battery-Refractometer/dp/B000HTNODE]Amazon.com: Robinair 75240 Coolant and Battery Refractometer: Automotive[/ame]
   / Does my new 2520 have too much antifreeze? #14
Car Doc,
That's a real good one Danny and a bargain at that price I am not kidding!!!
Its the same exact one I have that I got from Snap-On and paid $120 or so for years ago. And btw its -60 for Propylene glycol and -84 for Ethylene glycol which is most likely what you are using it reads both plus battery specific gravity . hth :thumbsup:
What I like about refractometers is you can test them by putting a drop of tap water on the lens, they say use inoized or distilled it doesn't matter they all freeze the same but it will show you it works its a very accurate tool.
   / Does my new 2520 have too much antifreeze? #15
I'd rather have too much antifreeze and not freeze it. If you go 50/50 you could freeze it and destroy the engine.
   / Does my new 2520 have too much antifreeze? #16
??? 50:50 is the ratio engine manufacturers want.....safest to run
   / Does my new 2520 have too much antifreeze? #17
Yes thats correct and there are several reasons that support using no more than 50/50 however it will freeze so one ratio doesn't fit all areas so if it doesn't get below -34 where we are than 50/50 is ok.
   / Does my new 2520 have too much antifreeze? #18
Snowmobile manufacturers recommend a 60/40 ratio of ethylene glycol to distilled water and these things are subjected to extreme conditions ;)
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
