Do you add any kind of Additive to fuel?
   / Do you add any kind of Additive to fuel? #1
Gobblin Tom
Gold Member
Western, PA
2011 JD 2520
Just curious if anyone adds anything to their diesel fuel for the winter months?
   / Do you add any kind of Additive to fuel? #2
There's a number of quality fuel additives on the market. I'm not necessarily a "brand" snob at all... I am familiar with what has worked for me over the year's and what is readily available (on the road - at home). So, I don't have to "hunt" for fuel conditioner when I need it - I use Power Service.
AKfish
   / Do you add any kind of Additive to fuel? #3
I use Power Service white bottle. I buy it at Advance Auto or Walmart.
   / Do you add any kind of Additive to fuel? #4
Lots of posting son this subject so you can find many preferences. Also consider winter fuel. May have to ask around where it can be purchased.
   / Do you add any kind of Additive to fuel? #5
In 12 years, have never used anything.
   / Do you add any kind of Additive to fuel? #7
I've used a lot on a lot of different vehicle and the one that I can really tell the difference is the RED LINE.
Some guy did test on the net and showed it dissolve soot compared to the other brand that did nothing to clean the fuel system.
I can tell when I'm using it and the times I run out and am not running it.
Red Line does not use any harmful alcohol based thinner such as Amsoil. in its products which can be too reactive.Red line relies on the synthetic base lubricator to lubricate and maintain the injection systems, negate any water build up in the fuel if any occurs, the agent gently dissolves any carbon build up if any as it acts as a anti carbon build up on valves and piston crowns which may damage valve ports, etc and block injector jets to an irregular spray pattern.
I can under stand that in parts of the US and Canada where low temps are experienced and the use of a lesser quality winter grade with lower below required Cn values,Red line RL 85+ and RL 85 anti gel would be of more importance as to it's anti gelling properties and extra cetane value for the boost for a higher fuel burn.
Red-line for my vehicles has proved itself over the four full years of use to assist in maintaining my engine to it's original OEM specifications, with out any issues or injectors leaks rust or carbon build up etc.
Might pay to read this local write up, maybe better than others available from Red Line outlets. It's not everyone's solution, for me it's proved itself and that is what counts at the end of the weeks work a reliable diesel engines.
www.google.com/url?sa=t&source=web&ct=res&cd=7&url=http%3A%2F%2Fwww.redlineoil.com.au%2FUploads%2FDownloads%2Ffinalbook%2520reviseI%281%29.pdf&ei=C4oBSsntK4WQtAOyiqz7BQ&usg=AFQjCNHII-51M7ETrg7z0HzqKeldAUKtzA&sig2=prDCRyMpkpjM_EjpXmgc2Q
   / Do you add any kind of Additive to fuel? #8
Stanadyne Performance formula. Works great and yes it does benefit your engine and fuel system. Because someone has not used any and not had any problems? does not mean it is not beneficial.
   / Do you add any kind of Additive to fuel? #9
Powerservice is what I use. You will find as many opinions on this, as you will on which oil to use.
   / Do you add any kind of Additive to fuel? #10
Like stated above, depends on the quality of your supplier. If you are in doubt, add some powerservice (white bottle).
That brings me to the fuel itself.
No matter what the brand of tractor, the engines all operate the same and ULSD is just that, low sulfur and sulfur lubricates pumps and injector pintles so I always add CAT lubrication additive to every load of fuel that gets delivered.
Better safe than sorry....
JCB 2145 (A47477)
JCB 2145 (A47477)
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
