L5030 Price/Opinions
   / L5030 Price/Opinions #11
Don't know about everyone else, but that's what I use in addition to the nifty e-bay electric fan I bought this summer.
Now if you could retrofit a reverse flow fan, all would be wonderful......:)
   / L5030 Price/Opinions #12
The reverse fan sure would be nice. I ran into some late season native grass mowing this year that would clog my filters up in under an hour.
   / L5030 Price/Opinions #13
See, I suffer the same fate all the time when haying. The chaff migrates into the radiator net or the intercooler or the condensor and there is no air compressor out in the field for a quick blow off.
I have limited success with the cordless leaf blower I use on the knotters on the 575. My electric auxillary fan setup works and it's electrically reversable but it only gets the condensor/intercooler, not the radiator itself and both radiators (9000 and 105) bet loaded with chaff, especially in the bottom third.
When the radiator gets loaded, flow from the fan is diminished (through the intercooler and condensor and to a lesser extent, the transmission cooler) so things heat up, in the cab and in the gearbox and I tend to use the hydraulics (which generate heat) more in dusty, chaff laden conditions, like moving rounds from the field to the trailers where driving across the bailed fields stirs up the chaff left on the ground by the bailing operation and even more so when bailing wheat straw behind a rotary combine.
I'm pretty happy with the electric fan mod but it's not a pancea for everything. I still have to blow out the radiator every night. It's a ritual along with greasing the front axle pivots and checking the lubricant levels.
All in all, it's better than the 5030 was but still a PITA.
Deere has it right with reverse flow fans and I've seen reversable fans for tractors, but never Kubota's plus I suspect they are pricey.
I apologize for hi-jacking the thread as this is about a 5030, not our larger tractors. I always liked my 5030. It just wasn't big enough to run my equipment. I found myself many times with the engine wide open trying to hold 540 pto. That don't work, both from a longevity standpoint and a fuel consumption standpoint.
   / L5030 Price/Opinions #14
I bought the most powerful hand held gas powered Stihl leaf blower I could find and use it in the field on our L5030 and M8540, not as good as an air compressor, but it usually gets me through the day.
I don't do any haying, so I can get by with it.
   / L5030 Price/Opinions #15
My blowgun is just a cheapy with some 3/16 copper flexible tubing bent at the end. I blow it out once a day when bushhogging or raking. I've got an extra air compressor that I'm thinking about putting a pto adapter onto so I can have air in the field. Some of those russian tractors have air on them due to the air brakes for trailers, good idea I think.
I appreciate everyone's comments. I think I will make the upgrade soon. Now i just need to convince the wife that WE need it. Maybe I should have let her blow snow on a couple of the -20 degree nights without a cab! I don't hay with it, however I do let one of the local farmers take the hay off the field so I don't have to mow as much. It works well for both of us. For those of you who need air in the field, why not try one Of those Viair compressors with a small storage tank. It could be wired right to the battery and strap the tank somewhere on the machine. Just a thought. Northern tool has some smaller 12 volt compressors also.
   / L5030 Price/Opinions #17
Don't need too; got a cell phone and my wife is retired and makes free service calls. She likes tractors and such as much as I do.:thumbsup:
Oh and it was her idea to buy the L5030 HSTC and stop running tractors between farms.:thumbsup::thumbsup::thumbsup:
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
