Concrete bucket
   / Concrete bucket #42
I have decided to pump it.
Customer will allow us on the driveway with concrete truck, so now were close enough to pad location to pump. Probably ~ 100'.
Sounds good. What is the project to be? Barn or some sort of stamped concrete deck(got one of those this last year and love it btw) But what's this for if you don't mind me asking?
   / Concrete bucket #43
What are you using to dig?
   / Concrete bucket
It's an 8'x10' concrete pad with frost footings for a 48KW Eaton generator.
Me and 2 helpers with shovels. :laughing:
It' so steep I can't even get my mini-ex down there.
   / Concrete bucket #48
Yes. Customer allowing me to bring concrete pumper on his driveway shortened the distance from truck to pad by 300'. Otherwise, I was on my way to buy concrete bucket. Looks like a very usefull attachment.
Probably the safest way to do it also. Sounds like its turning out to be quite the project!
   / Concrete bucket #49
I have a Furukawa loader it has a 1/2 yard bucket, when I was building my shop, getting a pumper up the mountain was expensive, $1,000 to $1,400 a time when we did the footings, I tacked in a couple of pieces of angled plate to give me a pour spout about 2 feet wide.
The truck could get-to about 1/2 the footings they poured from as far as they could I had the loader in the middle, he would fill the footings then fill the bucket and I did the part he could not get to when the job was done I ground out the plate. For the cost of a 4 ft square piece of steel cut and ground to fit it saved me a grand.
When we poured the walls I put the pieces back in and used it to redo a cracked section of sidewalk and make a ramp, to my back yard picnic table, barbecue area. Both of those areas were about a thousand ft from the pumper.
Worked for me!
   / Concrete bucket #50
i'm a little late to the game on this one, since you've already got it planned out. my question was: do most of the small pad jobs you do allow you to use a ready-mix truck, or are you using a small mixer on site? if you are using a small mixer and were then going to move it by tractor, what about a 3ph pto mixer? i just brought home a slightly-past-abused 3 point hitch pto driven mixer. it needs a bunch of work, but they still make similar ones new if you are in business. with that you can back right up to the forms & place it where you want it. i don't know how bad the cost is compared to a bucket, but it would cut out a piece of equipment, and the transfer from mixer to tractor.
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
