BX24 diff lock disaster ... How many others have had this problem?
   / BX24 diff lock disaster ... How many others have had this problem? #41
Define "spinning"? I mean, if you are stopped, and the pins are not lined up with the mating holes, pressing on the pedal will not engage the components? However, if you maintain a light pressure on the pedal and move slowly (with the back wheels turning at different speeds) then it should eventually engage. Right?
That's how I've gotten mine to engage, but kind of paranoid about it now...:confused2:
   / BX24 diff lock disaster ... How many others have had this problem? #42
Me too. If the pins don't engage when you are stopped, that's the only way you can get the rotation done so that they do. I guess just let the one wheel spin very slowly ?
   / BX24 diff lock disaster ... How many others have had this problem? #43
The way I engage it, and have been successful in doing it this way, is to stop the wheels from turning, engage the diff lock then very slowly depress the treadle pedal until you "fell" the pin engage, (you can tell when it engages) then go for it.
It's rare that I use it tho, normally I'll go to 4WD when I loose traction. I've found that if 4wd doesn't get me out, it's time to pull it out w/the F150 4x4 Offroad :D
Dave
   / BX24 diff lock disaster ... How many others have had this problem? #44
Seriously, some one on here really said that there is a design flaw because when the pin breaks it can wedge in the bottom and break the case???? A manufacturer can not plan on every stupid thing that customers do to there machines. Diff pins break from people engaging them while the wheels are turning 99% of the time. If you are in that 1%, sound like you are having a bad day. As for breakage after the fact, it is a fact of life. Again, the manufacturer can not make room in the bottom of the case for any part in the transmission that may come apart in any circumstance. As for larger pins, in my experience, these pins are fine for the hp of machine they are used on. If you make the pins larger, then the next weakest thing breaks. Operate it as intended and most of these issues would go away. Not sure why everything now days is the manufactures fault, a lemon, or poor design. Pay the bill and move on.
   / BX24 diff lock disaster ... How many others have had this problem? #45
As for engaging the diff lock, here are good instructions:
1. Let the wheels come to a complete stop.
2. Press the diff lock pedal (or lever, etc.).
3. Slowly allow the tractor to move forward (or reverse) at least 1 full revolution of the tire.
4. Do what you need to do to get unstuck.
The main thing is that you can not engage one while a wheel is turning at any real speed. The "shock" load to the pin is too much.
   / BX24 diff lock disaster ... How many others have had this problem? #46
I've never actually used the diff lock to become unstuck, just to get the extra traction when mowing up or down a fairly steep slope, at an angle to the slope. The uphill tire will break traction. If I have a bit of pressure on the lever, it slips down into place and I can climb or descend the slope no problem. I was using it instead of 4WD so that when I get to the end of a pass and spin around to come back I get the tighter turning radius when in 2WD. With the way this little BX24 is built like a tank, never imagined the diff lock mechanism would be a little bit fragile... thus, my comment about being a bit paranoid to use it this way anymore.
This is my first Kubota. The only ag tractor I kept from when I was farming is a JD 4020, about a 1967 if I remember correctly. It's 2WD and also has a diff lock you engage by pressing on it with your heel. I've had to quick stomp on that thing countless times over the years when needed (breaking traction under a load) and never had an issue, but certainly that was built differently - I don't think it is a pin that engages.
Anyway, this thread has been pretty valuable to me as I know to treat the diff lock much more carefully - it isn't a big ol' ag tractor after all...
   / BX24 diff lock disaster ... How many others have had this problem? #47
Lock the diff BEFORE you get stuck, then you dont get stuck, very simple.
Learn to read the ground and plan your driving and have right amount of speed/ momentum/gear. Basic offroad knowledge. As with all operator locable diffs, you should lock the diff when both wheels travel at the same speed, slightly steer back and forth to engaged or disengaged. Specifc operation with the BX24 difflock as member Volfandt described.
   / BX24 diff lock disaster ... How many others have had this problem? #48
1 -Seriously, some one on here really said that there is a design flaw because when the pin breaks it can wedge in the bottom and break the case????
2 - A manufacturer can not plan on every stupid thing that customers do to there machines.
3 - Diff pins break from people engaging them while the wheels are turning 99% of the time. If you are in that 1%, sound like you are having a bad day.
4 - As for breakage after the fact, it is a fact of life. Again, the manufacturer can not make room in the bottom of the case for any part in the transmission that may come apart in any circumstance. As for larger pins, in my experience, these pins are fine for the hp of machine they are used on. If you make the pins larger, then the next weakest thing breaks. Operate it as intended and most of these issues would go away.
5 - Not sure why everything now days is the manufactures fault, a lemon, or poor design. Pay the bill and move on.
1) Seriously, it sounds like a design flaw to me. If the pin was designed to shear so that other parts do not fail then provision should be made not to destroy the other parts.
2) I agree, however, this does not sound like someone doing something stupid to their machine. It sounds like normal operation to me.
3) It has already been noted that the only way the Diff Pins engage is with the wheels turning.
4) Making room in the bottom of the case for ANY part is not what is being discussed, just the part which is the weakest link and meant to give before the other more valuable parts.
5) When damage occurs during normal operation we naturally look to the manufacturer. Normal operation results in wear and tear, not major damage.
   / BX24 diff lock disaster ... How many others have had this problem? #49
Perhaps if we just avoid any situation where the tires could spin we wouldn't get stuck AND we wouldn't need a Diff Lock - a win win situation. ;)
   / BX24 diff lock disaster ... How many others have had this problem? #50
I use the locking capability regularly on a particular small area of my lawn where I need to mow a fairly steep section at an angle. On the way up and the way down I'll keep a gentle pressure on the locking lever with my heel. Often it will engage when the high rear wheel starts to loose a bit of traction. The lever will press down and "slip" into diff lock smoothly. So, of course, I am engaging the lock while the wheels are spinning... didn't realize what a no-no that can be. I am thinking I'll just use 4wd from now on.
Addict, Sounds like very reasonable use to me. On an older tractor that had independent brakes (a foot pedal for each wheel) I used to feather the high wheel to do the same thing but the Diff Lock method sounds better because the tire would never spin continuously and the method doesn't require as much attention to the up hill tire. The independent brakes make for tight turns at the end of the row too. :thumbsup:
   / BX24 diff lock disaster ... How many others have had this problem? #51
I sure thought it would be reasonable use. I've never used diff lock on any tractor to get "unstuck" as some folks seem to think is the only use for it. I've always used it in a situation where one wheel is breaking traction, to prevent the wheel from breaking traction.
I sure agree with your other point - if the pin is intentionally fairly fragile to sheer and prevent other more major breakage, but then can itself cause some similar major damage, seems not completely thought through in the design stage...:eek:
Kubota's response has been "TS.". My dealer has asked the Kubota rep to talk to me a couple of times and he refuses to even talk to me.
I like the machine overall, but based on Kubota's refusal to even talk to me about the situation, I may go green when it comes time for a new tractor.
   / BX24 diff lock disaster ... How many others have had this problem? #53
Sorry to hear that. It looks like you have a problem with the local dealers, not kubota. I Just don't have a problem with my diff lock, and just like any color of tractor, when something breaks its easy to blame the manufacturer. If I broke the diff lock more then once in short period of time, then yeah I would blame them.
Really, I think every color have thier own quirks, its just a matter of what break down and how hard it is to get it fixed that would influence your decision next time.
No, he problem is not with the dealer. The dealer has asked the Kubota rep to contact me on at least two occasions. He refuses to even discuss the issue with me.
The dealer is a local company who I've dealt with for years. They treat me very well.
   / BX24 diff lock disaster ... How many others have had this problem? #55
I think the biggest problem here next to mistakes done by operators engaging the differential lock is selecting the wrong tractor. The BX is more or less an "estate" tractor.
If you are going to be in the mud and off in the brush you need at least a B series. I know people are not going to like hearing this but the BX just does not have the clearance or the drivetrain compared to the Bs for this type of work. The BX was made to fill the niche for improved areas that still needed lighter tracxtor work. When I see people putting duals on BXs to plow dirt with and having to put on these other guards to keep brush out. I see them as just taking the cheaper route and sometimes pushing the equipment way past its limits. Sometimes you need to stop and see if you should get equipment better suited for your needs and learn how to properly operate it instead of pointing fingers at the engineers. Kubota has been making tractors for a long time and has not climbed to the top by taking shortcuts in engineering. Some of these dealers need to take more time in accessing the correct tractors for their customers as many are getting put into the wrong one just to get the sales at a cheaper price point. I mean come on redesign a treanny case so when the pin breaks it does not jam??? how about not engaging when spinning.
David Kb7uns
David Kb7uns
   / BX24 diff lock disaster ... How many others have had this problem? #56
David Kb7uns
David, did you just chime in now or did you read the thread? Odds are that you CANNOT engage the diff lock at all if you are NOT spinning at least to some degree. You get 2 chances on a spin of the axle to make this happen.
This thread has been around for a while now and I don't recall the exact circumstances, but I don't believe the OP said he was at full throttle, full speed when this happened.
   / BX24 diff lock disaster ... How many others have had this problem? #57
David Kb7uns
David Kb7uns
Mowing the lawn is too much for this tractor??? I don't think so. If using the diff lock on a BX is overusing a BX, and too much for a BX to handle, why the heck did they put a diff lock option on a BX?
   / BX24 diff lock disaster ... How many others have had this problem? #58
Tasking things out of context If the lawn is too rough then get a B
David Kb7uns
David Kb7uns
David Kb7uns
Dave,
Didn't engage while spinning.
As said before,Minot bitching that the pin broke ... But to cascade into a $3,000 repair due to insufficient clearance that virtually guaranties that the case will be trashed if the pin breaks IS a design flaw.
73,
carl - wk3c
   / BX24 diff lock disaster ... How many others have had this problem? #60
I'm not saying that diff lock pins should NEVER break. Nothing is unbreakable. My issue is with the design where, if it does break, it falls to the bottom of the case and gets pinched by the gear(s) and punches a hole in the case, resulting in a $3k repair bill!!!
Not having enough clearance to prevent that seems to me to be a design flaw. A broken pin should be able to sit in the bottom of the pan, rather than being pushed through the case, creating such extensive and expensive damage.
I would like to hear from everyone who has had this happen and investigate the possibility of getting some consideration from Kubota for the cost their design flaw has caused.
from my understanding the diff lock is not pins between the the diff carrier and ponions as this system is expensive to make as well as unrelable.
Can some one confirm that the diff lock is activated by moving the axle to lock the spider gear with the diff carrier. Can't seam to find exploded view.
I have seen damage to the leaver due to opperators jumping on the foot leaver. This is abuse and may cause a pin to be shared off. May be its other parts involved as well.
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
3650 (A47477)
3650 (A47477)
Yanmar YT359 (A53317)
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
17501-FL (A56857)
17501-FL (A56857)
M998 (A55852)
M998 (A55852)
