Convert Joystick
   / Convert Joystick
I tried again. almost broke the stick off.
I guess the cheap VTEKS loader just didn't think it was necessary
   / Convert Joystick #12
Do you have a joystick valve for your loader, or a valve with two levers?
How old is the tractor?
On the bottom of the valve, do you see a cap like device with two screws.
This joystick valve from Prince, is just an example of what a float assembly might look like. There are some little balls that drop in a groove when you are in float. If they are rusty or dirt is blocking the float action, you will need to inspect, clean and lube.
Look on page 7
http://www.princehyd.com/Portals/0/products/valves/LVManual.pdf
   / Convert Joystick
Hi J J
Not sure of the brand of the valve.
I looked at the link and my valve does not have the extra levers.
I will try to get some useable pictures of it to post.
Old Gray market 80s 1500d.
:thumbsup:Loader probably put on in Korea or Vietnam.Just guessing.
Thanks Again.
   / Convert Joystick
J J
Just for your enjoyment.:laughing:
Pictures of my loader valve.
Can you tell what I have?:confused2:
Bottom  view3.jpg Bottom
from front3.jpgFront
Right side toward loader3.jpgRight Side
Top View3.jpgTop
   / Convert Joystick #15
In the top picture, it looks like you have a bolt miss. Is it? That might not let the valve work right.
   / Convert Joystick #16
Have you removed the caps on the lift spool to check the condition of the parts under the caps.
The picture I posted above, is an example of a detent assembly. If you remove the cap, be careful as springs and steel balls may spring out. have a magnet close by or a rag over the cap when removing.
You may not have a float, but most loader valves do.
I also noticed a valve body bolt missing. Sometimes, loose bolts or over tighten bolts will cause a valve not to work correctly.
   / Convert Joystick #17
I did a bit of research on my Vteks loader valve that might help. Mine had the marking BLB - a company out of itally with a small distributor in the US. I sent pictures of my valve to this distributor who contacted Itally and researched it for me. My loader valve did not have float or Power beyond. The fix was about $300 for a new valve...so I am waiting until I REALLY need it. BTW, my valve model was a bm40
Here is a link to some of the BLB valves in case they look like yours.
.:| BLB .:. Home page |::..
   / Convert Joystick
Thanks again to all.
I will need soom time to digest all this new info.
Let you'all know later.
   / Convert Joystick
Well I was worried about the screw missing in the Valve cover.
I took the boot off and took a few pictures.
I don't know why the hole is empty but there is nothing for a screw to thread into.
See attached pics
   / Convert Joystick #20
The missing bolt I was talking about is on the valve body.
Post # 14 left side. There is a bolt and nut on the right side.
Those two holes on the top plate with the lever attached, is probably for use if the other holes get worn out.
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A52705)
2024 ATLAS CORPO...
POLARIS RANGER 570 RTV (A51406)
POLARIS RANGER 570...
2017 Ford Transit 350 Handicapped Van (A55788)
2017 Ford Transit...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A54757)
UNUSED FUTURE MINI...
