Rubber edges for back blade and front end loader?
   / Rubber edges for back blade and front end loader? #1
Ed Manuel
John Deere 1050
Hsllo - I am trying to work out what to put on my 5' back blade (on my JD 1050) to keep it from causing damage to a new driveway of asphalt (which is has slopes and valleys for drainage) plus stone blocks at the edges that are held in place with cement and not entirely smooth. The heavy rear blade and my front end loader could do some real damage without some softer edge or a rubber shoe to keep the metal from direct contact with the driveway.
I am going back to the discussion that is already on your site to review it some more.
I can obtain some old tires but what can you use to cut them up?
Thanks for any suggestions.
Ed
   / Rubber edges for back blade and front end loader? #2
Welcome to TBN. :)
   / Rubber edges for back blade and front end loader? #3
Ed
Conveyor belt. Look in yellow pages or google suppliers in your area.
   / Rubber edges for back blade and front end loader? #4
I use a 1' strip cut from a horse stall mat. The height allows me to flip it upside down when 1 edge wears out, although it's on the 3rd year and doesn't show much wear.
   / Rubber edges for back blade and front end loader? #5
Do you drill holes in it and bolt it on?
Good idea BTW!
David
   / Rubber edges for back blade and front end loader? #6
WELCOME to TBN :)
I moved your thread to the Attachments Forum.
   / Rubber edges for back blade and front end loader? #7
how about some of that 1/2" thick rubber horse stall matting.
soundguy
   / Rubber edges for back blade and front end loader? #8
another idea for the back blade is get some pvc plastic pipe and cut a slot on one side then slide it over the cutting edge of the blade. You could prolly do the same to the loader also.
   / Rubber edges for back blade and front end loader? #9
might cut a couple slots in it for a bailing wire retainer.. but should work..
   / Rubber edges for back blade and front end loader? #10
Ed
Ed, here is how I did it to my fel blade. The rubber came off a local county snowplow. Real tough material, especially to cut with a utility knife. Works great though as I plow several neighbor driveways that are all covered in blacktop. No damage issues using this.
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A52377)
2019 John Deere...
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
UNUSED RAYTREE RTSG30 TRANSVERSE STUMP GRINDER (A54757)
UNUSED RAYTREE...
30ft Highway Trailer Co. Lowboy (A55218)
30ft Highway...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
