Rubber edges for back blade and front end loader?
   / Rubber edges for back blade and front end loader? #1
Ed Manuel
John Deere 1050
Hsllo - I am trying to work out what to put on my 5' back blade (on my JD 1050) to keep it from causing damage to a new driveway of asphalt (which is has slopes and valleys for drainage) plus stone blocks at the edges that are held in place with cement and not entirely smooth. The heavy rear blade and my front end loader could do some real damage without some softer edge or a rubber shoe to keep the metal from direct contact with the driveway.
I am going back to the discussion that is already on your site to review it some more.
I can obtain some old tires but what can you use to cut them up?
Thanks for any suggestions.
Ed
   / Rubber edges for back blade and front end loader? #2
Welcome to TBN. :)
   / Rubber edges for back blade and front end loader? #3
Ed
Conveyor belt. Look in yellow pages or google suppliers in your area.
   / Rubber edges for back blade and front end loader? #4
I use a 1' strip cut from a horse stall mat. The height allows me to flip it upside down when 1 edge wears out, although it's on the 3rd year and doesn't show much wear.
   / Rubber edges for back blade and front end loader? #5
Do you drill holes in it and bolt it on?
Good idea BTW!
David
   / Rubber edges for back blade and front end loader? #6
WELCOME to TBN :)
I moved your thread to the Attachments Forum.
   / Rubber edges for back blade and front end loader? #7
how about some of that 1/2" thick rubber horse stall matting.
soundguy
   / Rubber edges for back blade and front end loader? #8
another idea for the back blade is get some pvc plastic pipe and cut a slot on one side then slide it over the cutting edge of the blade. You could prolly do the same to the loader also.
   / Rubber edges for back blade and front end loader? #9
might cut a couple slots in it for a bailing wire retainer.. but should work..
   / Rubber edges for back blade and front end loader? #10
Ed
Ed, here is how I did it to my fel blade. The rubber came off a local county snowplow. Real tough material, especially to cut with a utility knife. Works great though as I plow several neighbor driveways that are all covered in blacktop. No damage issues using this.
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
HYSTER H55VM...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
John Deere 73 Inch Materials Bucket - Needs Carrier (A55218)
John Deere 73 Inch...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
