Using a subsoiler as a ditch digger
   / Using a subsoiler as a ditch digger #1
tpulley
Wake Foest NC
Kioti DK45SE
I have an idea... I am thinking of building a sible point subsoiler 4 inches wide that I can get to go down to about 12-18" deep. This will be used primarily for running drip irrigation feeder lines. I beleive I can easily get by with this depth as i will be completely draining each line at the end of the growing season.
It costs me about $100 to rent a ditch witch for a day. I need to do this once or twice a year. The ditch witches I have rented in the past do not do a great job of keeping straight lines or making wide turns. I am thinking the tractor with a subsoiler I could really get this done just as well.
Is 4" wide enough? I plan to put in 1 1/2 black plastic pipe. Would the tractor pull a 6" subsoiler point?
I have seen on everything attachments a trencher that hooks to the 3pt hitch but wince at the over $6 price. That would equate to me using a rented ditch witch over 60 times and no upkeep costs.
My tractor is a 45 hp Kioti 4wd.
Any ideas?
   / Using a subsoiler as a ditch digger #3
Trenchers straight line depends on the operator. Just like your tractor, you have to control it. I dont think you want to be hand digging a bunch of sprinkler lines which is what you would have to do with a subsoiler. It is not going to throw out the soil, rather just loosen it up. I dont think a middle buster would go 18" deep without sucessive passes and still would likely require lots of hand shovelling to complete a rather level ditch and it would be awfully wide for you to have to fill back in. I know I wouldnt want you in my yard digging a trench for sprinklers with a middle buster. Save your money and stick with the trencher. $100 per day for 2 days a year is not that bad and you will spend that much or more with all the hand labor to clean out and then backfill the larger ditches with anything other than a trencher.
PS: If straight lines are an essential for your, rent a bigger ride on trencher that will make much straighter ditches than the walk behind which is actually walk in front but backward which is likely why you get the curves.
   / Using a subsoiler as a ditch digger #4
I have "pulled" lines with my middle buster and it worked great. Got the idea on TBN
   / Using a subsoiler as a ditch digger #5
I found the standard subsoiler point worked just fine for 1" or 1.250" line:
   / Using a subsoiler as a ditch digger #6
There are threads about pulling the pipe under ground with a sub-soiler ... I had 4" drain pipe (flimsy) so I had to trench it in... I used a middle buster that is adjustable (can lower an extra 6" down.)
http://www.tractorbynet.com/forums/projects/227548-putting-drain-pipe-underground-middle.html
I had to make several passes and clean it out as I went. If not, the dirt would fall back into the hole. The project went better than most of mine... (it actually worked) but I had to use a shovel more than expected.
Thanks for the posts guys. I think the one in the link posted by TEG is what I need and want to accomplish. I am fine with it being a little bigger than my pipe. I can always fill in with the box blade.
The terrain I didn't mention earlier is mostly field, well at least for the initial test. I do have to run down a 150' beside a wooded secion to get to the crest of the hil. Then its all open field. Not very many rocks as it has been tilled over the last 50-60 years or so. Some pop up all along but we just remove them as the do.
So TEG, did you make or buy your "trencher"?
   / Using a subsoiler as a ditch digger #8
I'm pretty sure it was a close-out at Agri-Supply. They were changing to the fix/solid ones that looked like King Kutter at $50 more. I paid $95 IIRC, when I saw that it was adjustable, I had to have it.
   / Using a subsoiler as a ditch digger #9
This what I use for trenches. It is a hyd motor turning a 26 in carbide tipped wheel. Does an outstanding job.
You could make something like this with a hyd motor, blade disk, and carbide teeth. Mount it on the bucket , 3pt or make a push/pull trencher.
I also have the subsoiler for pulling pipe.
   / Using a subsoiler as a ditch digger #10
Those would be great if roots were an issue. Looks like the miniature version of what Vermeer makes to cut pavement. Nice!
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
SHELVES W/CONTENTS (A55745)
SHELVES W/CONTENTS...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2014 JOHN DEERE 672G MOTOR GRADER (A52707)
2014 JOHN DEERE...
2017 Bobcat T770 Compact Track Loader (A55314)
2017 Bobcat T770...
2020 Chevrolet Silverado 1500 Pickup Truck (A55852)
2020 Chevrolet...
