BeezFun said:
I don't see how the concrete is doing any good. Or is the post held up off the surface of the gravel so the concrete goes under the bottom of the post?
By not immediately setting the posts in concrete gives you the ability to make adjustments left to right / side to side. Of course you can't take forever because the posts will twist and warp within a few days of unbundling.
The gravel in the bottom of the post hole allows for drainage. Keeps the post dry.
We set all the posts, braced them four ways, than ran the wall purlins (2x6). We left the bracing on two sides (in and out).
At ceiling height, I ran a 2x10 on the interior and exterior of the posts.
Then filled the holes with redii-mix concrete.
Then we ran the rim joist around the bottom at the height of the future concrete floor.
After this was done (braces still on the posts - in/out) we set the trusses, which were 42' wide 10' OC (same as the posts). The trusses rested on the two 2x10's, and were bolted to the posts.
Tops of the posts were trimmed off, and the braces removed. Installed the roof purlins, insulated and sheeted.
It has held up to some pretty violent thunderstorms (80 - 90 mph winds or so). Short of a tornado it's not going anywhere.
I left out several additional measures that was taken (diagonal bracing, truss bracing, etc). The building is 42' x 68' x 14' side walls. It has 2 10' x 12' overhead doors, a man door, and a 14' slider.
My only regret was putting in the slider. Used it one time to work on a 13' 3 spindle bush hog RC. Now I have so much stuff in there...time to build another building!!!
