Antifreee question?
   / Antifreee question? #21
I have a quick question for FSE: Kabota just asks for permant antifreeze for my little BX24. I could find no specs other than that. I put in some green low silicate antifreeze, 4985 I believe. Should I add some SCA to it.
Thanks
You can but I doubt it is needed as Kubota made no reference to it. Adding it does improve the general metals corrosion resistance as diesel antifreeze meeting ASTM D4985 has some specs on general corrosion tests that it must pass. Adding any SCA to the coolant will improve the ferrous metals corrosion resistance even if cavitation pitting is never an issue as well as improving resistance to scale formation on hot surfaces. For engines not requiring such coolant with SCAs there is little likelihood that you will need to replenish them as they will not be consumed.
   / Antifreee question? #22
Thanks for the information. I think next time I will use the ASTM D6210 rated antifreeze that already has the SCA mixed in. I plan on switching my 99 Ford diesel to that and will use it in the Kubota.
Thanks for the help and Merry Christmas.
   / Antifreee question? #23
Thanks
And why did you add SCA to it? They do not have wet liners. If it passes the gm spec, it is fine by me.
   / Antifreee question? #24
Hi did not say that he did! He simply asked if he should.
   / Antifreee question? #25
What ever antifreeze and additive package you use get one that has an easily available test strip. Mixing additives does not make them better, it just makes testing them impossible to test. If you put in to much of an additive it is not better, read up on their data sheets, or oficial sites of the aditive to know, how they want their product used. Even if the engine does not have replaceable liners you can get scale build up and additive drop out and coating of the hot parts, you can get cavitation holes in the cast iron, and hot spots will cause the cylinder to crack at the top. I would like to see every engine with a coolant filter, to keep the system clean. Just draining you coolant, after use, into a pail and letting it settle, then pouring 90% of it back will clean out the system if done regularly, and you will see what comes out. That works for me and I did it in many of my vehicles. I have a little loader that will get a flush and refill as well as my Duramax, the coolant is 5 years old.
I use a mixture of Arm and Hammer washing soda and Dawn dish washer soap, for flushing,:thumbsup: if there is any signs of oil residue to clean cooling systems. even ones filled with fuel or oil.
   / Antifreee question? #27
Even if an engine does not require supplemental coolant additives for cylinder wall cavitation pitting protection, the common supplemental coolant additives available will improve general metals corrosion protection. Nitrite as found in the old Nalcool product, Pencool additives, Fleetguard DCA2, Caterpillar coolant additive, Baldwin BTE, as well as Wix and Napa products....will improve the ferrous metals corrosion resistance even if the engine does not need that additive for pitting protection. The other supplemental coolant additive is sodium molybdate. It is a potent aluminum corrosion protection agent as well as being part of the most robust pitting protection available. More engines are being built with increasing amounts of aluminum content such as cylinder heads, water pumps, as well as thermostat housings and now radiators. Coolant additives composed of nitrite and molybdate are sold by Baldwin as BTA, Fleetguard as DCA4 as well as there are several coolants that use the combination of nitrite and molybdate as all or part of the ptting protdection and general metals protection. The most common (but not the only) are Fleetguard ES Compleat, Fleetguard Fleetcool EX, Caterpillar ELC OAT with nitrite and molybdate, Caterpillar Diesel Engine Antifreeze Coolant, Shell Fully Formulated Phosphate-Free, plus a few others whose names escape me at the moment. It has been mentioned that mixing nitrite only or nitrite/molybdate additives causes problems. That is not true. Most coolant manufacturers will state that mixing of their coolant with other brands will not cause harm. Adding one to the other only increases the values of the total additive package. Stories about mixing are completely untrue. The last topic to be addressed is the belief that only wet liner engines need SCA. The original Caterpillar V8 diesel truck engines, 1145, 1160 and the later 3208 were all parent bore designs. Parent bores use the cast-in cylinder design. Those engines require the use of SCA or coolants formulated with SCA to protect against pitting failures. The original International 6.9, later 7.3, the 7.3 Turbo (PowerStroke) and the last one from Int' the 6.0 PowerStroke (DT345) all are parent bore designs requiring and SCA per International Truck and Engine Company. Ford may not always have agreed! The Cummins 5.9L, ISB 5.9 and the latest ISB 6.7 as well as the Duramax diesel are examples of parent bore diesels that do not have the need for SCA. As I stated before, using coolant with SCA provide much better anti-corrosion properties than plain 'green' antifreeze. Not required but will not hurt either.
   / Antifreee question? #28
Even if an engine does not require supplemental coolant additives for cylinder wall cavitation pitting protection, the common supplemental coolant additives available will improve general metals corrosion protection. Nitrite as found in the old Nalcool product, Pencool additives, Fleetguard DCA2, Caterpillar coolant additive, Baldwin BTE, as well as Wix and Napa products....will improve the ferrous metals corrosion resistance even if the engine does not need that additive for pitting protection. The other supplemental coolant additive is sodium molybdate. It is a potent .....
Could help but it is not needed. I have not used SCA since my old. I have
used, Toyota collants (super long life etc), Prestone, Fleetrite (normal made in Canada), and some others and never had a coolant issue.
Heck even the military does not use anything special in there engines. At least when I work on the MRAPs, FMTV etc.
It is not a powerchoke here, I had one too. Use any EG coolant it will outlast you. Reading WAY to much into this.
   / Antifreee question? #29
I my case it looks llike I can just use the D6210 anti-freeze that I use in my Ford in my Kabota. A small step to simplfy my life.
I understand I can continue to use the D4985 in my Kabota that I have in there now.
   / Antifreee question? #30
I my case it looks like I can just use the D6210 anti-freeze that I use in my Ford in my Kabota. A small step to simplfy my life.
Will be doing a flush n fill in my '97 Powerstroke sometime soon. Already have a supply of Fleetguard precharged with SCA and several gallons of distilled water.
If ever my Kubota B3030 needs to be maintained or topped off, it'll get the same thing after reading over FSE's posts.
Having fewer items around the garage at maintenance time will simplify things.
   / Antifreee question? #32
JJZ 109,
Where did you get your Fleetguard Precharged?
Tractor Supply carries it. But it doesn't come cheap. It was $15.99 a gallon.
I guess that I was mistaken about the name. It's Fleet Charge.
Not sure about your '99 Powerstroke, but I've seen it recommended at Dieselstop for my '97 to also use distilled water when refilling after a flush. Apparently this eliminates the mineral content and other things found in tap water.
http://www.tractorsupply.com/fleet-charge-reg-fleet-charge-antifreeze-1-gal--8000177
   / Antifreee question? #33
Earlier in the thread, Nalcool was mentioned as an additive. Without reigniting the debate, would this be a good choice regardless of the opinions about other additives? If so, where would you get it?
   / Antifreee question? #34
I did a search and found several different models of Nalcool out there. 2000, 3000, etc.
   / Antifreee question? #35
Every class eight truck dealer will have it. Detroit dealers will have it. I still have the nalcool bottles, Detroit calls it power cool, it has the antifreeze mixed with it.. Cummins calls it DCA2. Pen-cool. same stuff.
I give up arguing with idiots, use what you want to do not mix different types, and keep it clean.
If you do a flush, you can use Restore it is a great product, it is a little pricey I use a mixture of Arm and hammer washing soda mixed in a pail of warm water with a paint type mixer, and if any sign of oil a little Dawn dish washer soap pore that into anouther pail and with the system drained fill it and I use to use it for at least 1/2 hour or in a vehicle go to work and back. drain and refill till it comes out clean then do a couple of flushes. If you have access to air blowing a reverse flush threw the heater core is a good idea.
Minimum antifreeze protection should be -34F I do -50F.
You have a great new year.
   / Antifreee question? #36
Thanks for the reply. :)
   / Antifreee question? #37
Fleet Charge Fleet Charge Antifreeze, 1 gal. - 8000177 | Tractor Supply Company
But if a Kubota does not need it, why use it? His 99 or our 97 powerchoke (diff displacement) also has wetliners and does need it. Some Kubota's do and most do not.
Is dieselstop the same owner as the old Forddiesel.com? Owner is a %%^&*.
   / Antifreee question? #38
I'd use it for the reason I already mentioned. Because it's already in my garage and to keep from having several different brands laying around taking up space.
As far as Dieselstop, I don't know who owns it. Don't really care. Some good guys there that have given me good advice, that's what I do care about.
   / Antifreee question? #39
have you seen a bottle of plain green stuff lately? many stores are selling it at 12.99$ which make sthe 16$ precharge look not that bad actually! .. mind you the sca/dca isn't too much mooney.. but then you have to test strip it.. and the precharge is already at correct mix.. etc. thus easier.. etc..
soundguy
   / Antifreee question? #40
Fleet Charge is available from most HD truck distributors like Freightliner, Kenworth, Wester Star, Peterbilt, Volvo, and International. You can also find Fleetguard ES Compleat from these same locations. Detroit Diesel distributors sell DD Power Cool additives and Power Cool Antifreeze (Fleet Charge). You can also get precharged coolant from your CaseIH dealer under their own brand label. Deere sells their own nitrite-free OAT but may have a precharged conventional coolant but not likely Fleetguard as Deere is only interested in selling their own private label coolants as they do make their own. Same story for Fleetguard and some other brands of filters like Baldwin or WIX. Many of these same dealers sell more than one brand of filters.
I see that NAPA is listed frequently. NAPA is actually more expensive but their selling point is they may have a wider selection on some equipment and may also deliver. NAPA filter products are manufactured by WIX as are Big A and CarQuest.
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
2016 Ford Explorer 4WD XLT SUV (A59231)
2016 Ford Explorer...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
(APPROX. 20) 4' X...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
