singing shower head
   / singing shower head #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I have a water saver shower head in our shower - it sings as the water pressure goes up and down - it is a high pitched sound - we have a country well system with a submergable pump any help would be appreciated.
   / singing shower head #2
Some of the old shower heads had a limiter, i.e., a washer with a small hole in it that fit in the female portion of the shower head where it screws onto the shower outlet. If so, just remove this washer. Otherwise, get a new shower head.
   / singing shower head #3
have you tried soaking it in CLR?
   / singing shower head #4
How about some background vocals, or piano accompaniment?
   / singing shower head #5
Does it sound like Allison Krauss? If so I would like to buy it. I think she is awesome.
   / singing shower head #6
Our shower heads do this also. I think this is pretty much normal with a submersible well pump. The only time they don't sing is when:
Wife doesn't flush the toilet.
Washer isn't running.
Dishwasher isn't running.
Wife isn't taking a shower at the same time.
Automatic horse waterer isn't filling up.
Water softener/ water treatment system isn't back flushing.
   / singing shower head #7
Pretty sure those are the lyrics to Taylor Swift's next country hit...with the word "love" slipped in there somewhere.
If it's in a tub, try pulling the knob on the diverter valve that swaps water from the spigot to the shower head a little more firmly.
   / singing shower head #8
Where we used to live a flushed toilet would get the person in the shower scalded. Singing shower heads were a welcome change.
   / singing shower head #9
Might check the faucet tip. A loose tip will make some strange sounds. The hot is the most likely, the heat makes the rubber get softer.
2008 Ford Taurus X SUV (A50324)
2008 Ford Taurus X...
STORAGE FEES (A52141)
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
