singing shower head
   / singing shower head #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I have a water saver shower head in our shower - it sings as the water pressure goes up and down - it is a high pitched sound - we have a country well system with a submergable pump any help would be appreciated.
   / singing shower head #2
Some of the old shower heads had a limiter, i.e., a washer with a small hole in it that fit in the female portion of the shower head where it screws onto the shower outlet. If so, just remove this washer. Otherwise, get a new shower head.
   / singing shower head #3
have you tried soaking it in CLR?
   / singing shower head #4
How about some background vocals, or piano accompaniment?
   / singing shower head #5
Does it sound like Allison Krauss? If so I would like to buy it. I think she is awesome.
   / singing shower head #6
Our shower heads do this also. I think this is pretty much normal with a submersible well pump. The only time they don't sing is when:
Wife doesn't flush the toilet.
Washer isn't running.
Dishwasher isn't running.
Wife isn't taking a shower at the same time.
Automatic horse waterer isn't filling up.
Water softener/ water treatment system isn't back flushing.
   / singing shower head #7
Pretty sure those are the lyrics to Taylor Swift's next country hit...with the word "love" slipped in there somewhere.
If it's in a tub, try pulling the knob on the diverter valve that swaps water from the spigot to the shower head a little more firmly.
   / singing shower head #8
Where we used to live a flushed toilet would get the person in the shower scalded. Singing shower heads were a welcome change.
   / singing shower head #9
Might check the faucet tip. A loose tip will make some strange sounds. The hot is the most likely, the heat makes the rubber get softer.
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2022 JOHN DEERE 317G SKID STEER (A51242)
2022 JOHN DEERE...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
New Holland...
