Mulcher Heads....What you runnin and WHY?
   / Mulcher Heads....What you runnin and WHY? #21
I thought that Cimaf could only sell excavator heads and could not sell any for skid steers or CTL's..... I know that they lost the lawsuit with gyro trac. Did something happen that I missed?
   / Mulcher Heads....What you runnin and WHY? #22
Cimaf has came out with generation 3 heads the rotor is slightly different from the cimaf/gyro trac rotor. So there suppose to be able to sell the gen. 3 in the states.
   / Mulcher Heads....What you runnin and WHY? #23
Sorry if I posted some mis-information. What do the new gen 3 heads cost?
   / Mulcher Heads....What you runnin and WHY? #24
I'm always amazed to see how facts often get distorted or reduced. So, to get things straight:
1. See in attachment the joint press release that Gyro-Trac and DENIS CIMAF issued back in December 2008, after they settled their dispute. The extra subtleties of the contract that was then signed are confidential.
2. I would like to invite anyone who receives partial information - such as what tuckinlugz received - to send me an email at frederic.denis@deniscimaf.com, giving me details of what they were told, and by whom.
3. As for the generation-3 heads, they are pre-production models using a completely new technology, different from the "technology developed by DENIS CIMAF" at the time of the signature of the settlement agreement.
  • CDP 20081212 en DC vs GT Settlement.pdf
   / Mulcher Heads....What you runnin and WHY? #25
I believe that I read this information on this site. I re-read the letter in your post as it seems like does say that DF can not make heads that attach as front mounted units ie skid steers etc. using their technology.
As for making a "new" technology, I was unaware of this.
Thanks for the info!
   / Mulcher Heads....What you runnin and WHY? #26
Anyone have an opinion on skid pro rotary cutters? skidpro.com
   / Mulcher Heads....What you runnin and WHY? #27
297 just run the 180D although the motor is a little small it works just fine. I ran one on my 148 for a year and no problems at all. The motor runs out of displacement pretty quick so the difference between min and max are not as apparent as with the smaller hp machines but it worked for us.
   / Mulcher Heads....What you runnin and WHY? #28
Robbie, told me it was impossible to run the 180d on the rayco without causing damage to the motor on the 180d. Did u upgraded the pulleys? Are U still running the cimaf on the 148? Bet it's amazing on it, got any videos of it running would love to see it in action with the 148.
   / Mulcher Heads....What you runnin and WHY? #29
Nope pulleys and all the same. The 148 doesn't put out nearly as much hyd flow as advertised all the time. It ran fine, like I said it would have been nicer to have a 160-180 cc motor but they don't fit in the housing. You are definitely stretching the 107 on there but..... It's up to you. It does cut very good on the 148.
   / Mulcher Heads....What you runnin and WHY? #30
The 148 burnt this spring so it's not running no more but it was a nice little machine. It had its issues same as them all but that's not the topic here. I don't intend to replace it as I have no use for any machine under 250 hp any more. Good luck.
   / Mulcher Heads....What you runnin and WHY? #31
Thanks, hope all goes well
   / Mulcher Heads....What you runnin and WHY? #32
what ever happened to mark?
   / Mulcher Heads....What you runnin and WHY? #33
Last time I talked to him he was getting out of it. Was tried of being away from his family all the time. But he could be grinding closer to home, it's been serval months since I've talked to him.
   / Mulcher Heads....What you runnin and WHY? #34
[...] It ran fine, like I said it would have been nicer to have a 160-180 cc motor but they don't fit in the housing. [...]
Note taken and sent to engineering. That should not be difficult; the 160 cc option being already available for the DAH-150E. Thanks for the comment!
   / Mulcher Heads....What you runnin and WHY? #35
Hey let me know wat the engineering department says
   / Mulcher Heads....What you runnin and WHY? #37
All there will be left is dust they chip so fine already lol. I'd like to see a chipper tool that never needs to be sharpened, never breaks or chips too lol.
   / Mulcher Heads....What you runnin and WHY? #38
Fred give me a call when the boys figure out a way to mount that 180 in the housing or how about mounting another 107 on the other side and offsetting the mount ? Hmmm :)
   / Mulcher Heads....What you runnin and WHY? #39
Twin 107's man that would be awesome like your way of thinking
   / Mulcher Heads....What you runnin and WHY? #40
Sorry for the late reply, I've been busy with posting the job offers - and we still have to post the one for the US attachment reps positions...
I will get back to you on the 160 cc in a DAF-180D frame. If it doesn't fit in there as is, then it means a new frame would need to be built.
As for a twin 107 cc version, we already have it in the DAF-225E (88-in cutting width). If there is need for such setup in a 74-in cutting width model, we'd probably want to offer it in the form of the heavier-duty 180E/180E3 (bigger drum storing more energy + drive shaft resting on its own set of bearings).
GIYI SF60-60" HYD SIDE SHIFT FORKS (A60430)
GIYI SF60-60" HYD...
UNUSED RAYTREE RMDB82-DIGGER HYD BACKHOE (A60432)
UNUSED RAYTREE...
2014 International Derrick Digger Truck (A55973)
2014 International...
John Deere 5090GN (A60462)
John Deere 5090GN...
CATERPILLAR 72" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 72"...
2015 FECON FMX50 HYD MULCHING HEAD (A60429)
2015 FECON FMX50...
