Where to add hydraulic fluid on Ford 3600??
   / Where to add hydraulic fluid on Ford 3600?? #1
Horses4Me
Ford 2600
I just got a Ford 3600, well I purchased the property and it was left. I need to do some bush hogging, but need to add some hydraulic fluid before I start. I can't get in touch with the former owner to ask, so I have come here.
Can anyone direct me to where to do this? I do not know the exact year, I am sorry.
Thanks!!!
   / Where to add hydraulic fluid on Ford 3600?? #2
Thanks!!!
Look for a large plug on top of the axle housing to the right of and a little behind the seat.
THANK YOU!!!!!! I was looking right at it the whole time :)
Have a happy new year!:thumbsup:
By the way how much fluid does it take? Is there a certain type, I should look for?
   / Where to add hydraulic fluid on Ford 3600?? #5
use utf fluid meeting the M2c134 spec.
rear axle and hyds are a shared sump.
tranny is it's own sump.
there is a hyd filter under the running board as well that should be serviced.
if this is a loader tractor, it is possible the loader has it's own sump and a front pump.. etc.
I believe the 3600 still uses a plug in the left rear side of the axle trumpet as a level check plug. I know the 4xxx's have it in a different place.. IE.. on the side in/near the round housing.. etc..
soundguy
   / Where to add hydraulic fluid on Ford 3600?? #6
soundguy
nope the level plug is on the right side when sitting on the tractor above the running board in the rear diff
   / Where to add hydraulic fluid on Ford 3600?? #7
so it's set up like a 4600 then...
Thank you everyone...if the tank is dry how much does it take 5 gallons?
   / Where to add hydraulic fluid on Ford 3600?? #9
Just unscrew the square end plug on the right side and fill until you see it coming out and put plug back in.
   / Where to add hydraulic fluid on Ford 3600?? #10
if it truly was dry.. I'd think the pump is toast, and rear end / diffy / axle / bearings / pto pearing and seal are very, VERY unhappy...
soundguy
Case W7 Wheel Loader (A55272)
Case W7 Wheel...
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
Tomahawk 42" Skid Steer Pallet Fork Attachment, Asset# 72 (A59076)
Tomahawk 42" Skid...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
2019 GALYEAN...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
