Where to add hydraulic fluid on Ford 3600??
   / Where to add hydraulic fluid on Ford 3600?? #1
Horses4Me
Ford 2600
I just got a Ford 3600, well I purchased the property and it was left. I need to do some bush hogging, but need to add some hydraulic fluid before I start. I can't get in touch with the former owner to ask, so I have come here.
Can anyone direct me to where to do this? I do not know the exact year, I am sorry.
Thanks!!!
   / Where to add hydraulic fluid on Ford 3600?? #2
Thanks!!!
Look for a large plug on top of the axle housing to the right of and a little behind the seat.
THANK YOU!!!!!! I was looking right at it the whole time :)
Have a happy new year!:thumbsup:
By the way how much fluid does it take? Is there a certain type, I should look for?
   / Where to add hydraulic fluid on Ford 3600?? #5
use utf fluid meeting the M2c134 spec.
rear axle and hyds are a shared sump.
tranny is it's own sump.
there is a hyd filter under the running board as well that should be serviced.
if this is a loader tractor, it is possible the loader has it's own sump and a front pump.. etc.
I believe the 3600 still uses a plug in the left rear side of the axle trumpet as a level check plug. I know the 4xxx's have it in a different place.. IE.. on the side in/near the round housing.. etc..
soundguy
   / Where to add hydraulic fluid on Ford 3600?? #6
soundguy
nope the level plug is on the right side when sitting on the tractor above the running board in the rear diff
   / Where to add hydraulic fluid on Ford 3600?? #7
so it's set up like a 4600 then...
Thank you everyone...if the tank is dry how much does it take 5 gallons?
   / Where to add hydraulic fluid on Ford 3600?? #9
Just unscrew the square end plug on the right side and fill until you see it coming out and put plug back in.
   / Where to add hydraulic fluid on Ford 3600?? #10
if it truly was dry.. I'd think the pump is toast, and rear end / diffy / axle / bearings / pto pearing and seal are very, VERY unhappy...
soundguy
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
JOHN BLUE 1000 GALLON STAINLESS STEEL TANK (A52708)
JOHN BLUE 1000...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
