mike paulson
- Joined
- Sep 4, 2010
- Messages
- 65
hi fellas, i am looking to purchase a very nice 1700 ford with bucket loader. are these good tractors and how is parts availability? thanks much
hey JC, yes i see there is tons of info on this tractor and parts availabilty is ample. i went onto Messicks tractor parts and they have just about everything from castings right down to nuts and bolts, also New Holland has anything one would need to keep a 1700 running.Mike,
I have one and love it. it does have limitation like anything else. It is quite capable for the purposes it is intended to. I have a ton of comments on it on this board and few threads I started when I bought mine. Do use the search on this board with my handle and you'll get hrs of reading and many illustrations. if you have specific question ask and 1700 owners here will oblige.
Welcome to TBN Blue,
JC,
hey JC, yes i see there is tons of info on this tractor and parts availabilty is ample. i went onto Messicks tractor parts and they have just about everything from castings right down to nuts and bolts, also New Holland has anything one would need to keep a 1700 running..
Actually, the most negative comment you recieved was from myself. I have 16 years experience at a New Holland dealership and am currently the parts manager there. I probably have a better handle on this issue than you do.also alot of stuff aftermarket online. some of the stuff is alittle pricey but thats just japanese parts for just about anything.
i was alittle worried by the responses i got on another site about the 1700, but these were from the old die hard Ameican made only Ford guy's. ..
i will be picking up this neat little machine this week.
Rick maybe you can show me what i'm missing here? here is the link, click on New Holland then put in 1700 on the tractor search. then click thru the catagories for engine, electrical, etc. link below..are you saying this is all BS?You are dreaming, my friend.
Aftermarket sources for engine parts, sheetmetal; and major castings for a 1700 are practically non-existent.
Best of luck. I hope you don't need anything more than basic wear & service items for it.
being that we are freinds now Rick maybe you can show me what i'm missing here? here is the link, click on New Holland then put in 1700 on the tractor search. then click thru the catagories for engine, electrical, etc. link below..
New Holland Parts Lookup Online Catalog
well Rick i have to admit you are as right as rain and im glad you made me check this out. i contacted Messicks and parts are impossible to find for these japanese Fords. i will not be making this purchase and will now direct my efforts into finding a good 600 or maybe an 800 Ford now.....thanks to all of you for the input...Mike PNot to be rude, but I don't work for Messick's, I don't base my comments about parts availability on their web content and I don't have to explain why what they indicate as available isn't 100% accurate 100% of the time. They do a pretty good job there and having parts pricing available is helpful in general and certainly doesn't hurt their business. This isn't about me getting in a pi**ing contest with Messick's, or you, for that matter. My comment about pistons for a 1500 was an example that I know about with absolute certainty.
When I write about parts availability my comments are based on what happens when I place an order with New Holland or what information I get out of New Holland's real-time parts data base. That is the best information anyone working at a New Holland dealership can get. If you want to go out and buy a 1700 that's fine. But if you think every part is readily available for that model, you are surely in for a dissappointment. And that is no different than if you were looking at any other brand of CUT of that vintage.
Rick, are the parts for the 20 series getting hard to find also.
Bill
...But if I do have one and cannot get the parts to repair it the tractor is worth a whole lot less...
Bill
Availability on this older stuff is hit and miss and miss is more common now than before. I sold a bunch of engine parts for a 1900 a month or so ago; oversize piston & ring sets, undersized crank bearings, gaskets, etc. Exhorbitant prices, but everything showed up in three days. Now we have a customer wanting to rebuild a 1500 and NH doesn't have piston & ring sets available in ANY bore size.
Oh yeah, Messicks' shows the 1500 standard piston & ring kits as available in 3-5 days. There are none in North America and none available worldwide in the CNH system. There are none on the dealer parts locator. CNH doesn't even list a current supplier of these pistons.
4WD parts are scarce and have been for years. Try to find a front driveshaft for a 1900, for example.
