JD 7000 Planter Restoration-Before and After
   / JD 7000 Planter Restoration-Before and After #21
   / JD 7000 Planter Restoration-Before and After #23
Pretty work. I am in the market for a 6 row 7000 preferably field ready but not completely restored as your son's is. Are those JD row units? I heard Yetter makes good replacement parts. Also do you know if there is a worth while difference between the 7000's vs 7200's? Thanks.
Here is what my Son, Greg says: The planter I redone had JD (Max Emerge) row units. It is my understanding that Kinze is the same unit. I think Yetter only makes accessories like no
tills, closing wheels, etc....Most 7200 Deere planters were vacuum. You
have to have a special tractor with high gpm hyd. pump to run the vac. 7100
is the same as a 7000 but is 3 point hook up.
Giyi Log splitter (A53316)
Giyi Log splitter...
Polaris Side by Side (A50324)
Polaris Side by...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A55788)
2017 Ford F-550...
378467 (A51572)
378467 (A51572)
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Greenworks 2700psi Portable Pressure Washer (A55787)
Greenworks 2700psi...
