JD 7000 Planter Restoration-Before and After
   / JD 7000 Planter Restoration-Before and After #21
   / JD 7000 Planter Restoration-Before and After #23
Pretty work. I am in the market for a 6 row 7000 preferably field ready but not completely restored as your son's is. Are those JD row units? I heard Yetter makes good replacement parts. Also do you know if there is a worth while difference between the 7000's vs 7200's? Thanks.
Here is what my Son, Greg says: The planter I redone had JD (Max Emerge) row units. It is my understanding that Kinze is the same unit. I think Yetter only makes accessories like no
tills, closing wheels, etc....Most 7200 Deere planters were vacuum. You
have to have a special tractor with high gpm hyd. pump to run the vac. 7100
is the same as a 7000 but is 3 point hook up.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
2001 Ford Escape (A53314)
2001 Ford Escape...
2018 KENWORTH T880 DAYCAB (A55745)
2018 KENWORTH T880...
Freighliner Tender Truck (A55301)
Freighliner Tender...
