JD 7000 Planter Restoration-Before and After
   / JD 7000 Planter Restoration-Before and After #21
   / JD 7000 Planter Restoration-Before and After #23
Pretty work. I am in the market for a 6 row 7000 preferably field ready but not completely restored as your son's is. Are those JD row units? I heard Yetter makes good replacement parts. Also do you know if there is a worth while difference between the 7000's vs 7200's? Thanks.
Here is what my Son, Greg says: The planter I redone had JD (Max Emerge) row units. It is my understanding that Kinze is the same unit. I think Yetter only makes accessories like no
tills, closing wheels, etc....Most 7200 Deere planters were vacuum. You
have to have a special tractor with high gpm hyd. pump to run the vac. 7100
is the same as a 7000 but is 3 point hook up.
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
2007 Amkus Rescue System (A55787)
2007 Amkus Rescue...
275 Gallon Fuel Tank (A50775)
275 Gallon Fuel...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
1967 Ford F100 (A47477)
1967 Ford F100...
2021 Ford F-250 (A55788)
2021 Ford F-250...
