Help with old Disk Harrow bearing indentification
   / Help with old Disk Harrow bearing indentification #1
seanhoffman
ford 1720
I need some help identifying my harrow bearing. My harrow is a 16 disk three point heavy duty....it is at least 20 years old. The bearing is flanged, bolted to a L shaped bracket. It is a friction bearing(not sealed) and there are two of these per gang. I have looked at all the web sites i could find with no luck......so im asking you.....
   / Help with old Disk Harrow bearing indentification #2
I ran into a similar problem with my Minneapolis Moline KS-1300 wheel disc a few years ago. An outer bearing was a mess. Couldn't find a replacement. So I rigged up a bushing.
IMG_0339 (Small).JPGDSCF0314 (Small).JPGDSCF0006 (Small).JPGDSCF0007 (Small).JPG
Good luck.
   / Help with old Disk Harrow bearing indentification #3
There are a few local places where I could take the old bearing and have it matched up for a replacement. If unable to find something online, might check around to see parts house could help match it or recommend someone who can.
   / Help with old Disk Harrow bearing indentification #4
Pics would help.
   / Help with old Disk Harrow bearing indentification #5
View attachment 245379View attachment 245380View attachment 245381View attachment 245382
Good luck.
looks like it is a 1" shaft you should be able to go to any indrustrial place that carry bearings and get a flange mount bearing self aligning, you may have to fabricate a plate to bolt it on these bearings are very cheep
Thanks everyone. I stopped by TSC and did some more research. It appears that I have a fairly common flanged bearing. Although the actual bearing I need will take some doing, I think i have it figured out.
Thanks again.....Sean
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
2004 Winnebago Sightseer 30B 30ft. Class A Motorhome (A55853)
2004 Winnebago...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
