Help with old Disk Harrow bearing indentification
   / Help with old Disk Harrow bearing indentification #1
seanhoffman
ford 1720
I need some help identifying my harrow bearing. My harrow is a 16 disk three point heavy duty....it is at least 20 years old. The bearing is flanged, bolted to a L shaped bracket. It is a friction bearing(not sealed) and there are two of these per gang. I have looked at all the web sites i could find with no luck......so im asking you.....
   / Help with old Disk Harrow bearing indentification #2
I ran into a similar problem with my Minneapolis Moline KS-1300 wheel disc a few years ago. An outer bearing was a mess. Couldn't find a replacement. So I rigged up a bushing.
IMG_0339 (Small).JPGDSCF0314 (Small).JPGDSCF0006 (Small).JPGDSCF0007 (Small).JPG
Good luck.
   / Help with old Disk Harrow bearing indentification #3
There are a few local places where I could take the old bearing and have it matched up for a replacement. If unable to find something online, might check around to see parts house could help match it or recommend someone who can.
   / Help with old Disk Harrow bearing indentification #4
Pics would help.
   / Help with old Disk Harrow bearing indentification #5
View attachment 245379View attachment 245380View attachment 245381View attachment 245382
Good luck.
looks like it is a 1" shaft you should be able to go to any indrustrial place that carry bearings and get a flange mount bearing self aligning, you may have to fabricate a plate to bolt it on these bearings are very cheep
Thanks everyone. I stopped by TSC and did some more research. It appears that I have a fairly common flanged bearing. Although the actual bearing I need will take some doing, I think i have it figured out.
Thanks again.....Sean
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
2004 BMW 545i Sedan (A55853)
2004 BMW 545i...
