Front tire chains on 3720 with R4 tires
   / Front tire chains on 3720 with R4 tires #21
regarding the hose support------------------I did order a front mounted snowblower so perhaps the wire support came with that. We have had very little snow in northern Minnesota to date but the temperatures have been above normal right around 30 degrees during the day. That has resulted in very slippery conditions and I am very pleased with the steering control of the 3720 with front chains now. I am currently using loader arm mounted blade because the road is still wide enough so I don't have to blow the snow over and beyond the banks.
SNOW... whats snow. I dont think i have ever seen the stuff....at least this season:laughing:
   / Front tire chains on 3720 with R4 tires #22
Here are some pictures. The loader hoses are not a problem. I hope that shows in the pictures. The 90 degree elbow on the power steering does get very close to the chains on the right hand side of the tractor. I have programmed myself to avoid the very sharpest right hand turns. Next year I plan to put the front tires in the wide position and that should give me a little more clearance.
Mine will just touch the steering cylinder rod, in the most extreme, where the hydraulics are howling turn. so I just avoid that.
Regarding flipping the front rims, I did the rears, cause I needed that little extra clearance for the rear chains. But when I tried the front, it looked way out of whack. The rears are hardly noticeable, but the fronts did not look good, big difference when you flip the fronts, at least on my 4310. Not sure if it's even recommended. I left mine on the regular way.
JB
   / Front tire chains on 3720 with R4 tires #23
JB
I flipped the front's on my JD110, too. They looked kinda funny... dished out. But, I wanted that extra clearance for the chains. The question of rim strength/hub bolt strength crossed my mind.
Four years and just over a thousand hours - it's all good!
Before the 110; I had already used my JD970 for just over 4 years with the rims turned out like that. Chains in the winter, too. Left the rims like that year around. No problems. Just made sure that the bolts were torqued and tightened in a "star" pattern.
AKfish
   / Front tire chains on 3720 with R4 tires #24
I've gotten used to the fronts flipped around and have not had (knock on wood) a problem on my 4300 (either with ruining rims or handling chains)
   / Front tire chains on 3720 with R4 tires #25
There are some different shapes, but for my 455 hitch part number M96981 is what I use.
The model 3720 square loop is LVU17400
pictured here:
Note from my dealer: LVU17400 is $72.70 M134828 from a 59 snow blower is $20.00 Both are hose supports
I had him order the M134828 for me. I hope it's the right one.
There is also a Ubolt type hose retainer on the loader frame that mine did not have. I plan to add this now that my hood is pretty much rubbed through the finish...
   / Front tire chains on 3720 with R4 tires #26
I put chains on the front of my 3320 2 winters ago and left them on year around for traction on the hills no regrets . I had to replace two cross links do to the ledges , wear from gravel roads have then a little thin , I will replace if they wear out not for a while I hope.:thumbsup:
   / Front tire chains on 3720 with R4 tires #27
:thumbsup:I have run rear chains year round for 23 years.
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
7033 (A51691)
7033 (A51691)
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
