Subsoiler build ...
   / Subsoiler build ... #11
. . . I'm am wanting to add coulters in front of the rippers... the coulters will cut the sod and hopefully not tear up so bad for hay field renovation. . .
I admire your DIY attitude, but I just bought one. I let somebody else do the "figgerin'."
This is what I have: Hay King Renovators
Here it is on the back of the JD: John Deere 5085M pic2 - TractorByNet.com Photo Gallery
Note the coulters in front of each tooth, and the shear bolts on the shanks. You have the right idea.
   / Subsoiler build ... #13
That is a fine looking build--and it certainly does the job. Around here we only need to go 12"-14" to shatter the hardpan and improve drainage. The fear is too much depth in the wrong ground can "invert" the topsoil and that should be avoided. Good job, good results and happy it worked for you.
   / Subsoiler build ... #14
Wow nice build!!:licking: I wonder if the shanks had more forward angle if the HP requirement might be reduced to make it easier on the tractor. Also if the shanks were drill and bolted on instead, it could give you some adjustment for angle and the bolts could serve as "shear" pins. Just an idea.:cool:
Either way I like the build.
I slept on it and am thinking the same ... my next move along with the coulters is to cut the shank ... not sure where yet. At that cut I can angle the lower part of the rippers and use grade 5 bolts.... just bolt the cutoff part to the side .... Gotta study what angle to put them.
I didn't know coulters where going to be so hard to find ... I thought surely there would be some used ones around.
   / Subsoiler build ... #16
I think that is a nice build.:thumbsup:
About the shank might want to consider a parabolic design. Very popular for large V ripper plows.
   / Subsoiler build ... #17
BLUE I've bought coulters in the past(new)(complete assymbl.) from : DN Equipment
Boone
   / Subsoiler build ... #18
For Coulters, do you have any implement salvage/grave yards or used implement dealers in your area? Here in the corn belt we have several and if you willing to dig through their scrap piles you can some times find coulters etc..
Just a thought and nice build from scrap. Usually when I am done the scrap looks like a bigger pile of scrap....
Roy
Roy
No such thing around me. The corn belt ... man the few times I've driven thru your country its like a couple equipment dealers in every town.
Once in Walnut Grove Mn ... I spent hours walking thru the used equipment.
2013 Freightliner M2 106 Stellar 12621 6-Ton Mechanics Crane Truck (A56858)
2013 Freightliner...
2020 Ford F-150XLT (A57148)
2020 Ford F-150XLT...
2011 SOUTHWEST  GOOSENECK (A58216)
2011 SOUTHWEST...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
7ft Metal Shell Pump (A57454)
7ft Metal Shell...
VERMEER R23A TWIN BASKET HAY RAKE (A58216)
VERMEER R23A TWIN...
