Vicon RV 1601 or Vermeer Rebel 5500
   / Vicon RV 1601 or Vermeer Rebel 5500 #11
Is there a brand you guys would suggest over the Vermeer? Or, is it basically down to taste when you start picking between the major brands?
Would the 5610's be enough to push a 6x4 or 6x5 Vermeer baler, or would that be pushing it a little too much when the chamber gets full and pulling up an incline?
the 605 M requires 100hp, the 604M requires 80hp, the 665 rancher requires 75hp where as the 5420 rebel requires 50hp, if you stay wihtin those requirements you should be just fine, ...like a buddy of mine has said, "if it aint green or yellow, I dont run it!"
   / Vicon RV 1601 or Vermeer Rebel 5500 #12
you have a nh tractor have you looked at nh balers they are the easiest to run if you get a twine baler with auto wrap
   / Vicon RV 1601 or Vermeer Rebel 5500 #13
I had a vermeer , 503I ran several thousand bales thru it , no problems only 1 belt laceing. sold it went to JD 457 several thousand thru it no problems yet. when I say thousand I mean close to 8 vermeer , 10 JD. Vermeer or JD for me only. Ive said it b4 and say it again vermeer had the first BIG round baler. You cant beat xperience! I bought the JD because I got a better deal on the 457 then compareable vermeer and I like JD equipement. just my 0.02cts.
   / Vicon RV 1601 or Vermeer Rebel 5500 #14
The key is matching the baler to your tractor. I think you will find that most of the used 604 & 605 balers have been turned more that the 5500 Rebel you ar looking at. In purchasing a used baler it is about the value of the baler available. NH, MF/AGCO, JD & Vermeer all make good balers. New Holland is the most sold round baler and the other 3 are all about the same in numbers.
At 700 bales a year the 5500 Rebel baler will rust out before you wear it out. The Pickup will go 20,000 to 40,000 bale before a cam track rebuild. Sand wears any pickup out quicker. The Hay DR
   / Vicon RV 1601 or Vermeer Rebel 5500 #15
Taste. Personal preference. Whatever you want to call it.
For me, It's JD or Vermeer round balers.
Hey Big Foot do you know Tippy and Keith Leblanc in Scott, LA. They are one of my TecoStar dealers.
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
