Lifting Chain Length
   / Lifting Chain Length #1
LHS Inc
Gold Member
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
I got Ken's Bolt on Hooks last week and installed them. They really are a great product, glad I got them.
Now I'm ready for some chains for lifting.
I know a lot of variables go into it as far as the job you're doing but I'm just checking to see what is a good average length you guys are using.
I plan on getting 5/16 grade 43 chain with a slip hook on one end at Lowes this week.
Thanks
   / Lifting Chain Length #2
Thanks
I use 2 chains. One is about 6-7 feet in length (somebody gave me this chain), the other is a 20' length.
You can always choke them in those grab hooks to reduce the working length of the chain.
Thanks Roy. I was thinking of one 20 footer and maybe a shorter length. Nice to know what works for you guys.
Good idea about choking the chain in the grab hooks, I hadn't thot of that.
   / Lifting Chain Length #4
A chain just a wee bit too short is mighty aggravating but if one knows how to tie a clove hitch a chain is never too long.:thumbsup:
   / Lifting Chain Length #5
LHS Inc - Did you drill holes in your FEL to mount the hooks? If so, how did you go about drilling them? Thanks.
   / Lifting Chain Length #6
I use chains with grab hooks. That way I can make it as short or as long as I need. No need for a slew of short chains. Just a few long ones.
And it looks like (I could be wrong) those are 1/2" grab hooks on your bucket.
Grab hooks only work well if you use the size chain they are made for or up one size or down one size.
If those are indeed 1/2" hooks, 5/16 chain you plan on buying is down 2 sizes. And I wouldnt tust a 1/2" grab hook on 5/16 chain. But thats just me. If it were mine, I'd buy 3/8 chain. Overkill....yes, but better than a 5/16" chain slipping or getting messed up.
If I am wrong and those are 3/8 hooks, then 5/16 chain will work just fine.
   / Lifting Chain Length #7
14 ft or 16 ft chains would be about right for tying that tractor onto a trailer, so might as well buy for dual use (-:
Just be sure to keep the chains as short as possible when carrying anything and carry it as low as practical.
I see SO MANY times ONE long chain attached to a bucket center hook and to get the load high enough the bucket is 10 ft or so in the air.
Do the geometry if you need to, but that swinging pendulum can QUCKLY get the tractor tipping over sideways. Basically you can be introuble as soon as the load swings outside the front wheel track.
Two chains are almost always better, though not always practical.
At least with two you only have fore/aft swing.
5/16 Grade 70 from Ken's Bolt on Grab Hooks
Yes drilled the holes with a cordless drill on one charge. Clamped them down marked the holes and removed them. Drilled with a 1/4 inch bit for the pilot hole then 1/2 inch bit to finish.
I took my time so it probably took me about 30 minutes to get it done start to finish, the great instructions made it very easy.
   / Lifting Chain Length #10
That's me. Grab hook on one end, slip hook on the other. I also keep a short chain, maybe 2 foot, with grab hooks on both ends which I use if I need to make a long chain short.
   / Lifting Chain Length #11
:thumbsup:
   / Lifting Chain Length #12
Then 5/16 chain would be perfect:thumbsup:
They just looked a lot bigger in the pics
   / Lifting Chain Length #13
I have alot of chain, some 20 footers, but mostly lengths 8-10 feet. I us those shorter ones the most, mostly 3/8 but recently did buy some 5/16 G70 since it was so cheap and well within the WLL of what I normally work with.
I would recommend OP to go with the G70, there has been some incredible deals at Lowe's and HF.
JB
   / Lifting Chain Length #14
Thanks
Sounds like you may be new to using your loader to lift with chain. You need to balance the load between the 2 hooks, at least for any substantial weight. Do not use just one hook for anything but very lite loads.
I think 2 chains are needed unless you have a center mounted hook.
That was the reason I went with the center mounted receiver, so I could use just one chain even with the heaviest loads I could lift. Must be a PITN having to use 2 chains.
JB
   / Lifting Chain Length #15
Where did you get the bolt on receiver? Or is that just a standard light duty automotive receiver?
Ken
JB
Thanks for the advice JB. I'm not new to loader work. Born and raised on the family dairy farm (sold the herd in 1998) with a JD 4010 with FEL so the common sense for loader work is there. It was always heavy and stable enough to handle any lifting.
Now these CUT's are a different beast altogether. I'm taking the safe approach and asking the questions to keep safe and the tractor out of the shop.
I'll be using one chain run thru both FEL grab hooks, center and hook it together and run down the center of the bucket for lifting. That way seems ok to me but if not let me know.
Not planning on hooking to one side only for any reason. From what I've read this tractors can get tippy.
You have a nice setup with your bucket. If mine was heavier duty I'd do the same thing.
   / Lifting Chain Length #17
Ken
I had this one made for me, obviously not to complicated, but as far as I know no one had one to buy at that time.
Now HF has one that would work perfectly for ~ $20.
5000 Lb. Capacity Step Bumper Receiver
I don't completely understand what you mean, but I agree you could use 1 longer chain to make the 2 drops. But you still have to, fool around balancing the load. For me I wouldn't consider anything but the center mount, if My bucket wasn't up to the task I'd beef it up.
The 2 grab hooks would come in handy for stabilizing a large bulky load in the bucket, can't do that as well with the single center mount.
But look at all the other options available with the receiver, the ease of using just one chain for lifting is just one benefit.
I had the 3/8" weld on grab hooks in my hand, but decided against installing them on my bucket for the reasons mentioned. I know they are still all the rage so I don't want to criticize them too much :)
JB
JB
I'm not the best at explaining things so let me try again. Standing in front of the raised bucket you take your chain and run it thru both hooks and leave enough of one end with a hook to hang down at the edge of the bucket. Take the other part of the chain and hook to it. You'll have a triangle of chain between the grab hooks and the front edge of the bucket with a long length hanging down to lift.
If anybody knows what I'm talking about and can explain it better feel free.
Another subject, JB I like what you did with your ballist box with the stone and pipes. When I get one I'd like to do the same thing. Does it give you enough ballist that you feel comfortable with? What size pipes did you use?
   / Lifting Chain Length #19
OK I got it now, that does sound pretty simple, couldn't picture it cause I never did it.
As far as the ballast box. I have since filled it with concrete to within 2 inches of the top. seems to be the perfect weight, even with the pipe in it. One 4", one 3" and four 1.5" pvc schd 40.
You might want to consider steel pipe, I thought about it to late but thought with plastic if you broke one you would be stuck with the short hole. So far I've had no problems, pvc is pretty tuff but the smaller ones are vulnerable, not so much the larger ones.
Maybe consider a way to drop the pipe in the concrete with a slightly larger formed hole, so you could take them out or change them if necessary.
That may be overthinking it, But for sure the pipes come in handy.
Good luck,
JB
Good luck,
JB
Was there a reason besides the weight difference that you went from stones to concrete in your ballast box? What was the weight difference between the two? With the stones did the pipes shift around any? What type of concrete did you use?
Sorry for all the questions. Yours really does look nice.
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 MACK P164T (A58214)
2020 MACK P164T...
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A59228)
1994 Generac...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
