JD 4520
There is a float and a solid position on your 3 point. It is manual. It is well described in the manual. Basically the adjustment is on the lower arms on each side. You will want them both to be in float or fixed.
That's a ground-following mechanical feature of the vertical links, it's related to tasks like mowing. OP question is whether there is a hydraulic function that will hold an implement at a fixed height without floating when it hits a high spot. Answer is still position control.Basically the adjustment is on the lower arms on each side. You will want them both to be in float or fixed.
Did you - or did you not - learn something about your new tractor? If yes, there's no need to use ignorant and question in the same sentence. Lighten up.sorry about my ignorant post
