question about the 3pt on 3000 series tractors
   / question about the 3pt on 3000 series tractors #11
There is a float and a solid position on your 3 point. It is manual. It is well described in the manual. Basically the adjustment is on the lower arms on each side. You will want them both to be in float or fixed.
   / question about the 3pt on 3000 series tractors #12
That's a ground-following mechanical feature of the vertical links, it's related to tasks like mowing. OP question is whether there is a hydraulic function that will hold an implement at a fixed height without floating when it hits a high spot. Answer is still position control.
I do however envy you for having draft control on that 4520. I had it on my last two tractors, but it's unfortunately unavailable on the 3x20 series.
//greg//
sorry about my ignorant post
   / question about the 3pt on 3000 series tractors #14
Did you - or did you not - learn something about your new tractor? If yes, there's no need to use ignorant and question in the same sentence. Lighten up.
//greg//
Yes I learned. I was referring to my upright post toward Greg.
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
