question about the 3pt on 3000 series tractors
   / question about the 3pt on 3000 series tractors #11
There is a float and a solid position on your 3 point. It is manual. It is well described in the manual. Basically the adjustment is on the lower arms on each side. You will want them both to be in float or fixed.
   / question about the 3pt on 3000 series tractors #12
That's a ground-following mechanical feature of the vertical links, it's related to tasks like mowing. OP question is whether there is a hydraulic function that will hold an implement at a fixed height without floating when it hits a high spot. Answer is still position control.
I do however envy you for having draft control on that 4520. I had it on my last two tractors, but it's unfortunately unavailable on the 3x20 series.
//greg//
sorry about my ignorant post
   / question about the 3pt on 3000 series tractors #14
Did you - or did you not - learn something about your new tractor? If yes, there's no need to use ignorant and question in the same sentence. Lighten up.
//greg//
Yes I learned. I was referring to my upright post toward Greg.
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
