New Husqvarna 346XP Yikes
/ New Husqvarna 346XP Yikes #101
Hey Jim fwtw thats not always the case although Husky put the chain they wanted on them 3/8 works fine long as its reasonable length.
I switched my 346 to 3/8 because I wanted to have one setting on my chain grinder for all my saws and one type chain to buy, not everyone may feel like doing this but I did.
My saw still screams however I run it with a 16" bar which I think is ideal for this saw no matter what pitch chain is used.
Granted the .325 narrow kerf is smoother and arguably faster (I dont see it but...) the difference is negligible to me and being able to sharpen it along with my big saws is a huge time saver. :thumbsup:
I talked with a few chainsaw places and they told me what I had previously posted. Being a mechanic and machinist I could see what they were saying and how a bigger tooth would take a bigger chip and slow the saw down. I have not tried a 3/8's chain on either of my 346xp's to see if there is a difference. I did have a chain wear out on me a few months back. It was replaced with a standard .325 chain because that was all I had laying around at the time, not a narrow kerf. I used both of my saws yesterday because I haven't had them running in a few months. I like to keep them running as much as possible due to the crap gas we now have. The standard chain is not as fast as the other saw with the narrow kerf chain. The RPM's are not up there like on the other saw unless I back off on my cutting. This weekend I will be replacing that standard chain with a narrow kerf chain. Both of these saws are running 18" bars.
/ New Husqvarna 346XP Yikes #103
I have a wooded lot about 3ac full of large oaks there are some that are to close to the house and I would like to take down.. I also heat our house with a wood stove. I cut a lot of wood for neihboring property owners as well most are ageing.
I thought the right saw for me was the Husky359 but after all the problems I have had with my Husky 445 Im hesitent to buy a non XP saw.
I dont want to regret not having the extra cc of the 359 but Im leaning towars the 346XP. I felt both saws at the dealer and like the compactness of the 346XP. I know that either way I will be happy because the 445 leaves a lot to be desired. for example (a single bar nut tensioner??) In my defense when I bought the 445 I was not doing anywhere near the cutting I do now..
If I were to go with the 346XP would you guys recomend changing over to a 3/8 chain>?
please advise...
I have the 357xp with 3/8" chain on a 20" bar and the saw handles it just fine. If I had to choose only one saw, thank god I don't, it would be the 357xp, has enough grunt to cut through 2' plus oak yet light enough to limb with after the tree is down.
It would be great if we could buy just one saw that did it all. There was a time when just about all my wood was cut with a 55 Rancher. By the end of the day that saw was heavy and I was wiped out. Now I use my 372xp for the felling and cutting of large trees. I can't use a heavy saw for limbing or cutting up small firewood like I used to. I was so glad when I found out about the newer 346xp. I can cut wood with this saw all day long without wiping myself out. It starts on the first or second pull when using the primer bulb. If Husky or anyone could make a saw as light as the 346xp with the power of the 372xp I would be very happy.
/ New Husqvarna 346XP Yikes #105
please advise...
Hello, I have a NE346,359,and 372 and the 346 gets the most use its my go-to saw I love it and its got 3/8 on it now so I can sharpen and buy one type chain.
With that said dont think for a minute a 359 is a slouch of a saw. Its got every feature an XP does right down to the muffler brace and magnesium case the only thing I see with it is its heavy its almost as heavy as a 372 with a lot less power. It doesn't make much sense I have both but I got a good deal on the 359. :D
I have rarely used my 359 its a spare big saw for when I have help otherwise the 346 has taken over all my firewood duty except the big trees and then its 372. The 372 is as much performance as the 346 in a larger package not a home owner saw in other words.
/ New Husqvarna 346XP Yikes #106
I understand what you saying. from reading this thread it seem some have gone from a 455rancher to the 346 and have been amazed. The price diffrence from the 346xp to the 372 or even the 357 is large but that being said they are two diffrent classes of saws. Most of you guys have said you have a 372 or a 357 but only break it out when you have really large wood to fell or buck. The question is would the 346 be up to the task of the occasional 20''-24'' tree?
Im sure it will be much more willing than my current saw which is a 445. Wich i over heated once last year while bucking a 24'' oak tree. yes the chain was sharp i think i just over work the little saw..
/ New Husqvarna 346XP Yikes #107
Absolutely its not ideal but having 1 saw do it all the 346 is real close to perfect imo. Make sure you get one w/o the cat if you can find one otherwise thats the first thing to go. (green gas cap is the cat equipt models fyi) And the difference between the 445 and this saw will be something like comparing a citation to a corvette. :)
You can have the best of both worlds if you want to stay with the .325 and get a good semi chisel chain from Baileys. The 95VP narrow kerf safety chain they come with is a poor chain for a saw with this much get up and go plus they dull easy imho.
I have gotten to the point I am even felling the bigger ones like that with my 346 w/16" bar taking my cuts from both sides as necessary and then bucking them with the 372 its so much easier on the shoulders.
There is no reason why you can't cut a 24 inch tree with your 346xp. Just don't expect the saw to cut it like a 372xp would. Let the saw do the work and not you back. Don't force the saw. If you have to force it there is something wrong. I use chisel tooth chains on all my xp saws. They in my opinion are the best cutting chain on the market. Yes, they do dull fast if you hit any grit, stones, or whatever. But when they are sharp watch the chips fly. Husky also reccomends running 89 octane or better in their saws. I run high test in mine.
/ New Husqvarna 346XP Yikes #109
I feel as though the 346 will be a good fit but I may hold out and see what the summer brings. perhaps Ill end up with the 357xp. I will look at the non cat version, is theres a way to order one that is non cat? Or is this something I would have to mod. after the fact? I remember the 359 I was looking at had the green gas cap. Looks like Ill have to go to the husky dealer again. ;)
/ New Husqvarna 346XP Yikes #110
The 357 is possibly going to be more a one saw fits all in your case its a very good 60cc class saw. fyi its the same chassis and basic engine as a 359 just more performance and money.
It will definitely do bigger stuff easier than the 346 no doubt just heavier and that is more a consideration as you get older believe me. Wagging a big saw around for trimming is a pain bucking is different there weight is your friend.
As far as cats go my 359 had the green cap I bought a 357 muffler from Baileys and adjusted my carb a little bit and made it a different saw you can do that with any Husky.
Ask your dealer for the non-cat models or search the internet. Husky quit letting dealers sell Pro saws online awhile back I dont know if thats still the case or not???
Great information Doc about the weight of a bigger saw or owning only one medium duty saw. I can attest to it. I bought one of my 346xp's from a dealer in the mid west for $425.00 delivered if I recall correctly. My 372xp came from a NY dealer for $700.00 shipped. Both were brand new saws. I found them listed on Craigslist as overstock saws or demo's. Neither of them had been used and were still in the original un-opened boxes. You could smell gas in the tanks. There was no oil in the oil tanks. There are some good deals out there to be had if you search far and wide.
/ New Husqvarna 346XP Yikes #112
Yeah Jim sounds like you are set up like I am with the 2 saw plan. :thumbsup:
It is great but expensive especially when you get to the point you realize Pro saws are the only way to go and need both at the same time making that coin toss and go with small or big to start with or do the middle ground its a tough decision.
I personally like having the lightweight 50cc 346 with a short bar and my 372 with a 20" (this is like a 454 in a nova) I can do everything I run across in my area. But like you and all the others we paid a lot of money.
I am done buying saws because I need them these saws should last as long as I do. (want is a different master) :)
When I was finally tired of the second hand Homelites and Maccullochs I bought one of the biggest 1 man saws Husky offered in my area and that was at the time a 372 had to special order it even. I bought mine in 2001 just after the 371 was phased out and I did all my trimming around the yard and everything with that big heavy saw and I enjoyed every minute of it the sound of a 372 is music.
I paid the price a few times because of it I cut my left knee twice to the bone and my left upper thigh real nice all because me running out of steam and getting careless thats not good.
Now wagging the little 346 all day is a piece of cake I never run out of steam just takes a few years of saving money etc staying focused on the goal. :thumbsup:
/ New Husqvarna 346XP Yikes #113
Sounds like you need to invest $60-80 in a good pair of chaps! That will probably be cheaper than the insurance deductible for your next ER visit!
/ New Husqvarna 346XP Yikes #114
Yeah agreed thats so true!!! I wear them now even in the heat of summer with shorts on its too late to fix the past but I got a set of full wrap Labonville Pro chaps and thats real good advice for all of us. :thumbsup:
Btw I am bad about going to the doc I fixed myself every time with betadine and butterfly bandaids and walked with a straight leg for awhile. My wife about passed out on the last knee injury and thats the one that convinced me I need ppe. :)
/ New Husqvarna 346XP Yikes #115
I have the same chaps, and they are great.
I agree on the 372xp wiping your butt out. I learned long ago before I ever came close to cutting myself with a chainsaw to never keep cutting when you are tired. I almost cut my leg one day with a 55 Rancher. That made me think twice about cutting for long periods of time. That was when I also broke down and bought a used Stihl 210c for limbing. I used to own a Pro Mac 650 with a 33 inch bar. That one got sold once I bought a used 262XP. Since then I have only bought xp saws. The other saw I own is a climbing saw with a 12 or 14 inch bar made by McCulloch. It says McCulloch Professional on the side of it. It weights about 7 - 8 pounds. I can one hand it if need be. My daughter uses the Stihl sometimes for cutting smaller trees. I had bought the second 346xp for her to use. I think it scares her just a little bit. We have a nice weekend coming up and I have downed trees to cut up. I have considered buying a pair of those leg protectors. After just missing my thigh muscle I have been extremely careful as to where the saw blade is at all times. I did take a nice 2 " cut out of my work pants that day with the chainsaw.
/ New Husqvarna 346XP Yikes #117
I went with the 357xp simply because I wanted to only take one saw into the woods with me. I found myself making the process of cutting firewood a real project. With two saws means to chains to keep sharpened, two to fill up, and two to lug around along with the liquids needed to keep them running and tools for the chain/ bar. At the time I was using an old 3 wheeler with a small trailer for firewood so space was at a premium. The 357xp seamed like a good in between size. Small yet large enough to use 3/8" chain.
Now I have a side by side and have retired the 3 wheeler so I can take two saws into the woods and all the tools and liquids for both for the saw and myself (nothing like having ice cold water). Sooner or later I'll add either a 576xp or 372xp for larger work. Yes the saw will be heavier but it's offset by how much easier and faster it will cut.
So there is mention of the green gas caps as being Cat saws. Both of my 346xp's have green caps on them. Is there a way to remove the cat from the muffler? Or is a Bailey's muffler the best way to go? I found out yesterday that you cannot get a chisel chain in the narrow kerf. I also found out that the Stihl Rapid Micro yellow chain will work nicely on these saws. That chain has no anti kickback features and is a narrow kerf chain. Part number is 3627 005 0072 or 23RMC 72E for the 18 inch bars. It is an exact fit for the original Husky chain. It has semi chisel teeth. I was told by two different dealers that this chain is much harder thamn the Husky chain. I can attest to the hardness of the teeth from hand sharpening the Stihl 210c that I own. I was a bit depressed that I couldn't find a chisel chain for my saw in narrow kerf. The one I bought previously to use is a also a semi chisel. It was supposed to be a chisel chain.
/ New Husqvarna 346XP Yikes #119
The cat mufflers can be easily replaced and Baileys is where I bought mine.
My 346 and 359 both had them. (353 is the replacement on 346, 357 is replacement on 359).
Mine both were stamped "cat" on them by the part number but I have heard others say theirs did not but still were cats. Safe to say if its got the green cap its got a cat.
Far as getting rid of the guts-short of cutting one apart there isn't any way to mod them, be a lot easier to spend the $40 and forget about it imo.
I found that I had to adjust my idle down and my mixture a bit richer on both ymmv there so be aware. You will most likely need some adjustment which is a critical part of keeping the engine alive so be careful is my advice on that have a shop adjust if not sure on it. And if you think your 346 winds up quick now just wait!!! :)
fwtw The gas cap on the 346 can be replaced with a 372 once the cat is gone so it looks better I had an extra 372 cap sitting around is how I know that and on the 359 the 372 cap doesn't fit so its still a bit ugly but I know its ok. :laughing: ;)
/ New Husqvarna 346XP Yikes #120
Oh man if you only knew...we had trimming chores from hades one spring after the worst ice and snow storm in 50 years when I buggered my knee one time.
We had 6" rain then hard freeze then 12" snow all in a weekend in December it broke down branches off every tree on my property. Come spring I took 13 car trailer loads clear full and strapped down off my 1 acre homestead. About as badly tangled on the ground all over the place as an old growth un-used forest area.
Yeah I was tired all right completely worn out fact wagging the 372 day after day trimming branches. If (famous last words) I would have had the little 346 back then it would have been absolutely no work at all as it was I had no choice all I had was one big saw to do it all live and learn. :D
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2022 North Star Pressure Washer (A60352)
2022 North Star...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
