1533 Engine Power Loss Intermittent
   / 1533 Engine Power Loss Intermittent #1
madmiller
Recently my 1533 has been intermittently lossing power, mostly while in higher RPM. The engine has outright stalled a few times. Changed fuel filter and cleaned out sediment bowl and added dealer recommended D-Syl to help with water and to condition injectors. Still same problem. Any ideas? Thanks!
   / 1533 Engine Power Loss Intermittent #2
Look for something in the tank. I had a similar issue and found a hornet floating around in the fuel that was just the right size to block the outlet from time to time.
   / 1533 Engine Power Loss Intermittent #3
I had the same type problem with bugs in the tank.
Did you have to remove the tank to clean the bugs out? If so was it difficult? Thanks!
   / 1533 Engine Power Loss Intermittent #5
When it happened to me, it was on a Cub Cadet lawn tractor. I fished out the spiders I could get hold of, then broke up the ones I couldn't, then unhooked the fuel line and drained the tank. Then I used my compressor to blow out the tank.
Thanks for the response! Today I am going to drain the tank and then feel around or look to see if anything is clogging the fuel flow. I am hoping for this to be the fix I am looking for!
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2022 John Deere 1025R (A53317)
2022 John Deere...
2022 BOBCAT E60 R2-SERIES EXCAVATOR (A52709)
2022 BOBCAT E60...
INGERSOLL RAND SD25F PADFOOT ROLLER (A52709)
INGERSOLL RAND...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
