1533 Engine Power Loss Intermittent
   / 1533 Engine Power Loss Intermittent #1
madmiller
Recently my 1533 has been intermittently lossing power, mostly while in higher RPM. The engine has outright stalled a few times. Changed fuel filter and cleaned out sediment bowl and added dealer recommended D-Syl to help with water and to condition injectors. Still same problem. Any ideas? Thanks!
   / 1533 Engine Power Loss Intermittent #2
Look for something in the tank. I had a similar issue and found a hornet floating around in the fuel that was just the right size to block the outlet from time to time.
   / 1533 Engine Power Loss Intermittent #3
I had the same type problem with bugs in the tank.
Did you have to remove the tank to clean the bugs out? If so was it difficult? Thanks!
   / 1533 Engine Power Loss Intermittent #5
When it happened to me, it was on a Cub Cadet lawn tractor. I fished out the spiders I could get hold of, then broke up the ones I couldn't, then unhooked the fuel line and drained the tank. Then I used my compressor to blow out the tank.
Thanks for the response! Today I am going to drain the tank and then feel around or look to see if anything is clogging the fuel flow. I am hoping for this to be the fix I am looking for!
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A58017)
2003 VOLVO VNL...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
