1533 Engine Power Loss Intermittent
   / 1533 Engine Power Loss Intermittent #1
madmiller
Recently my 1533 has been intermittently lossing power, mostly while in higher RPM. The engine has outright stalled a few times. Changed fuel filter and cleaned out sediment bowl and added dealer recommended D-Syl to help with water and to condition injectors. Still same problem. Any ideas? Thanks!
   / 1533 Engine Power Loss Intermittent #2
Look for something in the tank. I had a similar issue and found a hornet floating around in the fuel that was just the right size to block the outlet from time to time.
   / 1533 Engine Power Loss Intermittent #3
I had the same type problem with bugs in the tank.
Did you have to remove the tank to clean the bugs out? If so was it difficult? Thanks!
   / 1533 Engine Power Loss Intermittent #5
When it happened to me, it was on a Cub Cadet lawn tractor. I fished out the spiders I could get hold of, then broke up the ones I couldn't, then unhooked the fuel line and drained the tank. Then I used my compressor to blow out the tank.
Thanks for the response! Today I am going to drain the tank and then feel around or look to see if anything is clogging the fuel flow. I am hoping for this to be the fix I am looking for!
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
Sterling Dump Truck (A56858)
Sterling Dump...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
