Running new hyd.lines from rear remotes
   / Running new hyd.lines from rear remotes #11
On my Kioti i ran the hoses under the cab then right besides the hoses for the FEL. I also added a set of quick connects right nest to the quick connects that work the loader. That way i can easily disconnect these hoses if I unhook the loader.
And i mounted a set of disconnects up front by the loader.
   / Running new hyd.lines from rear remotes #12
First One, since you are in an area where there might be a bunch of sticks/twigs, etc. lying around I would make sure that the hoses are really tucked up tight under the tractor. You don't want that ONE piece of stick to grab the hose/s and rip it from the tractor. Also that is one great looking tractor! Stanley
   / Running new hyd.lines from rear remotes #13
Sent you a PM!!
10222 (A56858)
10222 (A56858)
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2005 Fleetwood Model D Camper, VIN # 5B4MPA7GX53402612 (A57453)
2005 Fleetwood...
