Reloading mistake
   / Reloading mistake #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I cought in time: 17 grains of H110 for 180 grains bullet in 357 Magnum
That would hurt a lot:)
   / Reloading mistake #2
Sure would.:eek:
   / Reloading mistake #3
Some of those kind of mistakes only get made once. Glad you found it!
   / Reloading mistake #4
I use a Dillon 650 with the powder check system. It lets you know if you double charged or failed to charge a case. It works very well.
   / Reloading mistake #5
so 3.5 grains over max load... yeah that would have been a "hand full of he**" Nice proof load, maybe 50,000CUP or so. or more. Glad you found it in time. I have seen a couple of ruptured topstraps, and blown out cylinders. Not up close and personal, but in the gunstore.
James K0UA
   / Reloading mistake #6
One reason I like compression or near-compression loads. You cannot always find a good load to do this unfortunately - particularly in pistol ammo. Very glad to hear you caught it in time Prokop!
   / Reloading mistake #7
You made a BOMB in a 357 casing! A double charge is a easy thing to do with pistol loads be carefull!
   / Reloading mistake
All it took was nodging the 10 grain weight from the groove on the bar scale. For some reason I did not notice it till the end.
Used powder thrower but set it up to this messed up value. Just a reminder to be more careful next time.
   / Reloading mistake #9
I have got a question for you fellas....I have 2 older 38 cal. police specials...one with a 4 " barrel and a snub nose...the one with the 4 " barrel must be over 60 yrs. old but in excellent condition the other, the snub nose is probably 30 yrs. old...Can I fire the new 38 cal. hollow points in these pistols or do I need to stick with just standard 38 cal. ammo ? thanks..
   / Reloading mistake #10
If the guns are sound, you will be OK with regular pressure .38 Specials, just not the +P load. A friend of mine had one made in the 50's he shot with the . 38 Special hollow points.
Those old Colts would get out of time, so you might want to check them or have a gunsmith look at them.
2018 Chevrolet Silverado (A55973)
2018 Chevrolet...
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
