Reloading mistake
   / Reloading mistake #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I cought in time: 17 grains of H110 for 180 grains bullet in 357 Magnum
That would hurt a lot:)
   / Reloading mistake #2
Sure would.:eek:
   / Reloading mistake #3
Some of those kind of mistakes only get made once. Glad you found it!
   / Reloading mistake #4
I use a Dillon 650 with the powder check system. It lets you know if you double charged or failed to charge a case. It works very well.
   / Reloading mistake #5
so 3.5 grains over max load... yeah that would have been a "hand full of he**" Nice proof load, maybe 50,000CUP or so. or more. Glad you found it in time. I have seen a couple of ruptured topstraps, and blown out cylinders. Not up close and personal, but in the gunstore.
James K0UA
   / Reloading mistake #6
One reason I like compression or near-compression loads. You cannot always find a good load to do this unfortunately - particularly in pistol ammo. Very glad to hear you caught it in time Prokop!
   / Reloading mistake #7
You made a BOMB in a 357 casing! A double charge is a easy thing to do with pistol loads be carefull!
   / Reloading mistake
All it took was nodging the 10 grain weight from the groove on the bar scale. For some reason I did not notice it till the end.
Used powder thrower but set it up to this messed up value. Just a reminder to be more careful next time.
   / Reloading mistake #9
I have got a question for you fellas....I have 2 older 38 cal. police specials...one with a 4 " barrel and a snub nose...the one with the 4 " barrel must be over 60 yrs. old but in excellent condition the other, the snub nose is probably 30 yrs. old...Can I fire the new 38 cal. hollow points in these pistols or do I need to stick with just standard 38 cal. ammo ? thanks..
   / Reloading mistake #10
If the guns are sound, you will be OK with regular pressure .38 Specials, just not the +P load. A friend of mine had one made in the 50's he shot with the . 38 Special hollow points.
Those old Colts would get out of time, so you might want to check them or have a gunsmith look at them.
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
2016 Nissan Sentra (A56859)
2016 Nissan Sentra...
2014 Audi Q5 AWD SUV (A56859)
2014 Audi Q5 AWD...
