Tractor tire goo
   / Tractor tire goo #11
Wince... Waiting for the air vs. nitrogen debate to start.... :laughing:
   / Tractor tire goo #12
We had to buy the nitrogen tire plan with the car, it was already added to all of them. It had insurance for a year. We did have one tire that lost air and would set off the sensor on the dash. I would not just go out and buy this service, as i still had to add air or take it to the dealer???The window price was $90.00...
   / Tractor tire goo #13
Before I did anything, I would get a $0.99 pack of valve cores and replace them. I had a slow leak in one my tires, replace the core and haven't had problem since.
   / Tractor tire goo #14
I had a 1100x16 front tractor tire (tube type) that was full of red locust bush thorns. Every time I patched th tube a new thorn would work its way into the tube. I tried one 16 oz tube of ameriseal instead of buying a new tire. I never had a flat on that tire again. Excellant product.
   / Tractor tire goo #15
for tubeless. remove valve stem.. add tube.. once you make sure there is nothing poking thru the casing...
soundguy
   / Tractor tire goo #16
Ok how does this stuff go in? Do you have to remove the valve stem? I guess this would fully deflate the tire.
That, or drill a hole in the sidewall - THEN see if the goo seals it up (-:
It can help to jack up the axle just enough to take most of the weight off the tire, then deflate it.
   / Tractor tire goo #17
most of the slime products I see for small tires.. you just remove the valve core after jacking up axle, and then slip hose over stem and squeeze- bottle it in.. add core.. inflate and drive to distribuite..
   / Tractor tire goo #19
I have both tubes and slime in the front tires of our Allis 5040. We also have a lot of Osage Orange thorns in our area. Last summer one tire was flat and the culprit was a big thorn located right on the top of the tire as it was setting. I pulled the thorn out, jacked up the wheel, rotated the wheel so that side was on the bottom and the slime would run to the hole. I then filled the tire with air and let it set for a couple of hours. I haven't had to put air in it since. I am a firm believer in slime. Others may have more data on other products but slime has worked well for me for many years, even on bicycle tires.
A. Metcalf
   / Tractor tire goo #20
if I lived in an oa area.. or locust area.. I'd either go with boots or radials or foam filled fronts.. them things are nasty..
Lone Star dump trailer (A55973)
Lone Star dump...
Earthway Spreader (A57454)
Earthway Spreader...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
2021 VOLVO VNL300 DAY CAB (A59575)
2021 VOLVO VNL300...
