other rem 760 ( .270 pump ) owners?
   / other rem 760 ( .270 pump ) owners? #41
I guess you could, but the neck lengths are different. I could probably neck size 300 Savage with same die too.
I would prefer to have the die set for each cartridge. Standard dies are not that expensive.
I do have a set of dies for each caliber I reload. And on another note guys be careful if you use 30-06 brass to make 270 or 270 brass to make 30-06, one could easily chamber it in the wrong gun squeeze the trigger and make one **** of a mess!:(
   / other rem 760 ( .270 pump ) owners? #42
I do too. Standard dies are not very expensive.
The custom dies for 30-06 Ackley Improved were pricey though. That brass is fireformed byt shooting standard 30-06 thru the Ackley Improved chamber. Then it sizes and seats with with it's own special sizer and seating dies.
   / other rem 760 ( .270 pump ) owners? #43
Where did you get your Ackley dies from? Did you have the dies custom made to the reamer?
   / other rem 760 ( .270 pump ) owners? #44
They are RCBS. I got the rifle from a friend recently. I believe they were custom; he had this done about 15 years ago. I remember him have the gunsmith work with RCBS to get all that done correctly. I'll have to ask him about that.
Sure shoots nice with 180gr Noslers :D
   / other rem 760 ( .270 pump ) owners? #45
Another sight advantage the .308 has over the 30'06 is powder column length. The conventional wisdom is that a shorter fatter catridge will give more consistant ignition from the primer. An example is the .300 WSM or Winchester Short Mangum. Bench resters especially, discovered that as the spark from the primer spreads into the powder, that a short fat column ignites more evenly than a long narrow column. Makes very little difference for hunting applications. However, at bench rest matches or 1000 yd long range the difference can be noticable.
   / other rem 760 ( .270 pump ) owners? #46
Nosler Partition is my go to bullet for hunting. sounds like you will have a fine hunting gun with that 06 A.I. should be able to produce 300 wm proformance, with less powder, and recoil!! :thumbsup:
   / other rem 760 ( .270 pump ) owners? #47
You should see the Elk my buddy has mounted in his livingroom. The rifle has black marks on the stock from riding horseback thru part of the area burned in the fire near Yellowstone.
   / other rem 760 ( .270 pump ) owners? #48
:thumbsup: I'm jealous
   / other rem 760 ( .270 pump ) owners? #49
Been a good week for finding deals,Sat bought Speeco tractor mounted t-post puller for $2.04. Now today bought this 760 in OTT-6 for $250 came with scope(lighted). Working now ain't had to much time too look it over . :dance1:
Boone
   / other rem 760 ( .270 pump ) owners? #50
Only own 4 .22 magnum rifles and never bought the more powerful calibers.Can't deer hunt in Ohio with a rifle AFAIK,so only owned shotguns and high-powered airguns. Have a 9mm pistole. don-ohio
Pallet of PTO Shafts & Hydraulic Cylinders (A50121)
Pallet of PTO...
W&A 3pt Ditcher (A50121)
W&A 3pt Ditcher...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
