Box scraper = chisel plow ?
   / Box scraper = chisel plow ?
I will be using it in my deer hunting food plots. About 8 inches deep would be plenty.
   / Box scraper = chisel plow ? #12
If you can't find something local, Give me a zip code and I would be glad to figure a shipping quote for 1 of our products. Ken Sweet
   / Box scraper = chisel plow ? #14
It seems to me that it would work. just be judicious with what you cut away. I think you could get by with just cutting 3-4 inches off the side panels and removing the blades. I can tilt mine and get the rippers down maybe 3-4 inches at the most. Cutting the bottoms of the side panels off shoudl give you 3-4 more. You'd probably have to round off the front corners of the side panels too.
Post pics.
   / Box scraper = chisel plow ? #15
I did a search and looked at the date on the original message!
I need to dig a trench to lay a wire from the meter pole to my shop. I don't want to put the back hoe on the tractor. I'm thinking of using the center chisel on the box to dig the trench.
I don't want to mess up the box.
Any one ever extended/made a shank with cultivator plow that would fill the bill?
Not interested in code/rules/danger etc etc.
RC
   / Box scraper = chisel plow ? #16
You mean like this.
   / Box scraper = chisel plow ? #18
Those subsoilers like in JJ's last pic can be had at TSC for under $200. $149 if I remember correctly.
And if you have access to a welder and some scrap steel, they arent that hard to make either.
   / Box scraper = chisel plow ? #19
That's what I was thinking; a longer bar the same sizes as one of the scarifiers and make a point (optional)on it and blow a hole through the flat side for the pin. If I had a TSC in AZ I wouldn't have to make my own; but what the heck that's half the fun.:thumbsup:
Thanks for the help!!
RC
2013 Lincoln MKZ Sedan (A48082)
2013 Lincoln MKZ...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A48082)
2022 Forest River...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
