Grease Testing
   / Grease Testing #21
. In that case, I like a good moly grease with a Timken load test of at least 80 lbs, but better would be 100 lbs. The soap base doesn't bother me much as its job is to hold the lubricant, but I try to stick with one type to avoid incompatibility.
What greases have you found that have a timken test that high???? Highest I have seen was 70????
But all that really measures is the EP property of the grease. And there are also the 4-ball scar and weld test that ALSO test the EP properties. And even comparing greases, these gan be different. One may have a higher timken test but a lower 4-ball wear and weld test:confused2:
But if you NEED an EP grease, higher #'s are better for the 4-ball weld and timken load tests.
But that isnt the only thing that matters. Those greases may NOT perform well in something that is NOT an EP application.
I had a thread on here I started about a year of so ago, and I listed a bunch of greases and gave some specs of alot of them. Mostly stuff we use at work. But unfortunatally I cannot find it. I dont know if it got deleted or what. But even going back through my profile of the threads I have started and it is nowhere:confused2:
   / Grease Testing #22
Just spent another few minutes looking and nothing???? I know it was on here, I dont visit any other forums. I know some of the greases I references were tribolube, fuchs renolit moreplex, and even searching them two I get nada. :confused2: Mods??????? Where did it go????
   / Grease Testing #23
For some reason it was removed back in May of last year. :confused:
It is now back. Here is a link to it.
http://www.tractorbynet.com/forums/oil-fuel-lubricants/206044-grease-lets-get-technical.html
:thumbsup:
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2019 TIGERCAT 234B TANDEM AXLE DE LIMBER (A54607)
2019 TIGERCAT 234B...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
