The gully to pond project
   / The gully to pond project
I'll try to get a better area shot posted. I've just been runnin' and gunnin' the last couple of days to try and beat the rain. The dam is not finished, but I think it is workable if we don't get a monsoon. One thing for sure is that if I have water in the pond, my current method of hauling clay will have to change drastically. I have a plan "B" and Plan "C" to my current plan. Barring a nuclear holocaust, I don't think I'll have to come up with another plan.:D
I couldn't do a whole lot yesterday because of the weather, so I decided to redo my "orientation" photo as requested by beppington. The current Bing Maps photos had to be shot last year. They are so up-to-date they are scary. I didn't have all my excavation done when the photo was taken, but it sure shows the project well underway. I've labelled all the areas so you can see where things are going. The last set of photos I posted of dam 2 are taken from the pond 2 basin looking directly down the gully looking north (or just slightly northwest). Because the gully is a big "V" shape and I had easy access to the opening of the gully, I decided to work from the pond end instead of cut down the bank to make a core trench. As I cleaned out the gully's silt, made it a lot deeper and then refilled with clay. Raising the clay and expanding outward to the sides is my primary plan. Each side of the gully "V" has clay down about 3' deep, so I remove the topsoil and sand and refill with clay. If I get runoff in the pond from these rains, I now have the option of cutting down the sides and coming in that way to bring in clay because my gully has been filled and the dam is firm, solid, and flat. It's also wide enough to drive my tractor on and turn around. Being able to maneuver was goal to get completed before the rains. If it looks like another dry day here, I'll try to get back in there today. Yesterday's rain really only settled the dust and there's no standing water.
   / The gully to pond project #203
OK I just about get the picture now :thumbsup:
I assume Pond 2 is lower than Pond 1? And "Gully" is lower than Pond 2?
So "Gully" is the sloped funnel that directs overflow toward the reservoir to the NW?
These questions may be obvious to others, but it's so flat here I've never had to even think about water flow or collection ... even though my property is almost entirely below the 100-yr flood plain! :eek:
I don't remember reading - Are you using instruments for this project, or just eye-ballin' it?
I have a surveryor's transit loaned to me by a friend, but when you have these wash gullies like I do, it's pretty obvious what is upslope/downslope. I also have a very good eye for level by sighting references that I know are level like on my house. All my final grades will be checked with the transit, but that takes two people to operate. If you look at aerial photos, it's hard to see where the slopes are located, but if you look at that photo I posted, the drop from my driveway to the bottom of pond 2 is probably 30' or more. I'll see if I can come up with a topo map of this area.
EDIT: I edited the previous post with an aerial photo with an additional topo map with my property outlined in yellow.
My rain gage has 3-1/4" in it this morning and I no longer have gullies. I have PONDS. Woohoo!:D My first pond is about 2' from overflow and my second pond is approaching the height of my partially finished dam. I'm going to have to go to Plan B on access to the dam because I can no longer drive through the pond basin and up onto the dam. I'll have to cut down the bank on each end and bring in fill clay that way. It's more trouble, but you won't hear me complain. This is fantastic to see all these years of planning come together and work so well. I get culverts this next week to install and safely control overflow.
I'll try to get some photos and post them as soon as it stops raining and I can slop through the mud to get them. It's still raining and could top out around 4" if showers continue to move over.
   / The gully to pond project #206
I didn't have time to read 21 pages so if this has been ask I apologize just head me in the right direction. Is there a general rule as to how many acres of run off you need to fill a pond. Or how do you fill a pond if not from natural run-off. I plan to make a small 1 acre pond that is in a natural depression. I'll dam off where the water currently runs out and down a hill.
I'm glad you didn't read this whole thread looking for that info because it isn't there. I'm sure there are general rules, but logic tells me that a 2-acre runoff in Oregon is going to have much more runoff than the same size area in Texas or the Mojave Desert. See what I'm getting at? It's very regional and depends on rainfall totals. Maybe there is a sliding scale for annual rainfall against runoff area and engineers use this to approximate their numbers. I don't know. I'd suggest that your local County Agricultural Agent or NRCS office could give you a quick and accurate answer based on your geographic region.
In my case, I have so much drainage that my design is to get the ponds full from spring rains and hope they last through the dry summer. In the case of my land, the erosion gullies from several hundred years of runoff have left no doubt about were and how much water flows during heavy downpours. All I have to do is build a dam to catch that runoff and then provide a safe overflow for the excess. That way I can retain most of the water and let the rest go into our 15 acre soil conservation lake which overflows into Big Sandy Creek leading to a major reservoir in the area.
   / The gully to pond project #208
Jim,
I hope you get these overflow culverts in before too much rain washes you dreams and planning away.
hugs, Brandi
Jim,
hugs, Brandi
Thanks Brandi. The rain has stopped now and the sun is out. It is really obvious that I need to add another foot (at least) to the middle of my dam. I better get out my nylon twine and line level. I thought my temporary overflow would be fine , but now I see it is not deep enough to prevent water going over the dam. Oops! :ashamed: I hope to have some photos by no later than tomorrow.
   / The gully to pond project #210
I'm not in Oregon, but I can see it. :)
We have around 50-70 inches a year and almost no runoff except roads, etc. I can turn on a garden hose full volume at the end of a garden furrow, and it won't run a foot down the furrow--just soaks in.
When I lived in the southwest desert, I could furrow irrigate a garden, but not here.
Bruce
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
1984 Gleaner A630 Corn Head (Deutz-Allis branded) (A57024)
1984 Gleaner A630...
Reel Mower (A55851)
Reel Mower (A55851)
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
