BX2200 losing power
   / BX2200 losing power #21
The metal can is the fuel pump. The 2nd fuel filter is under the hood next to the engine.
   / BX2200 losing power #22
2nd fuel filter or 1st depending on the flow of the fuel. They have 2 fuel filters.
No, the 2nd fuel filter was in the engine compartment, and it is the exact same part as the 1st one in the rear.
But there is no power going to it. How would this pump anything? :confused:
   / BX2200 losing power #23
Hard to believe but it is the fuel pump. See attached.
   / BX2200 losing power #24
Jp2code
This is your problem the fuel pump is not running. I had the same thing happen to me, the wires got pulled out when a stick hit them and wound the wires around the transmission cooling fan shaft. When you turn the key on you should hear a clicking noise, that is the fuel pump, that metal can. Fix it and your loss of power will be gone.:D
   / BX2200 losing power #25
I'll be damned.
Hey, that is a very nice diagram in your PDF. Is that part of your website? The parts there look much easier to identify than the parts diagram used by Coleman Equipment (who I've been using).
Where *is* the power wire for the fuel pump???
   / BX2200 losing power #26
I'll be damned.
see link below for photo of the pump, notice the location of the wire on the pump.
Messicks Part Search
Chevy 2500HD (A56436)
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
Zero Turn Mower (A59231)
Zero Turn Mower...
STORAGE FEES (A59575)
207272 (A52708)
207272 (A52708)
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
