Wet weather spring in driveway
   / Wet weather spring in driveway
Looks like some shaley limestone in the bucket. Did you go any deeper, to see if it gets pretty solid..?? More then likely that layer is fractured, and water is perking up through it, off the harder layer below.
I am assuming you are just digging out that mucky spot, and going to replace it with more decent material......
Bet that's some pretty nice water though, coming off that limestone aquifer..!!
Nope, did not want to go any deeper. Feared I was too deep as it was. Yes I am more or less digging it out and I am going to fill the whole area with gravel to a certain depth. That way I figure the water will filter through the rock then hit the perforated pipe downhill of it.
It does look like some nice water, when I went out today after it had been sitting, it looked good and clear. Resisted getting a big drink though...:laughing:
nrc i wish you all the luck in the world dealing with this problem we have put drains and tryed several drainage methods so far nothing works if we have a real wet spring we cannot get anything in half of our hay field we have about 10 of those springs that show up when we get alot of rain all the digging we have done over the years we could never for sure get to the actual point where the water was comming up.good luck
Thanks Sam, I need it. This is the same situation just not as widespread as yours sounds. I wish I could find an exact point but I believe I would have to dig up the whole hillside. I am just about there as it is.
Thinking maybe it would have made more sense to dig a big hole on the downward slope side of the driveway, thereby giving the water someplace to go?
Maybe, but the way it seemed to me (novice here) is by the time it reached a ditch on the downhill side of my driveway, it would have had to seep underneath the driveway. Which I believe is what was making it unstable to start with.
Hopefully I will not have to redo this any time soon, but live and learn! I have learned a lot in this process so far and everyone on this forum has been very helpful! Here is a pic today, I did a little more digging after this to smooth it out but this definitely relieved the water.
Wet spring with trench. by nrc17gto, on Flickr
   / Wet weather spring in driveway #32
Waiting for a car to drive into it :D.
I think once you setup a french drain, covered with some type of fabric, along with a layer of larger rock mixed with some dirt - compacted to make a road base. Top it off with a few inches of gravel... you shouldn't have anymore problems.
With the amount of water you had, I would think about draining it twice. Use a 45* joint (in blue) with two drain pipes (red) tied to a solid pipe (in yellow). It would be best to try and locate where the water is coming from...
Here is what I was planning. My thinking was that I would run the perforated pipe at the lowest point.
   / Wet weather spring in driveway #34
That ought to work, just be sure to get deep enough to rid the ponding at the outlet, or it will eventually soak out on down the hill, following the path of least resistance.
   / Wet weather spring in driveway #35
I guess I have som work no wonder the post man won't deliver anymore.
No just a pic of the Oregon trail ruts in Guernsey Wyoming. Was there last summer. that would do a number on your cars shocks.
   / Wet weather spring in driveway #36
Delete this one
   / Wet weather spring in driveway #37
Fill it with 3" crushed rock. No fines, all 3". Once it settles (and it won't settle much as three feet of 3" rock makes a nice bridge) you can cover it with 3/4 minus limestone for a nice surface.
3" clear crushed rock is spendy but will keep you high and dry.
Thank ya sir. I am torn from reading different post if I should wrap the perf pipe or not. And if so, do you:
1. Put paper on dirt, then gravel, then pipe, then more gravel and fold the paper over top
or
2. Put gravel down, put paper directly against pipe, then put gravel on top.
Either way I know I need a lot more gravel on top but I am just talking about the pipe at the moment.
Nick
   / Wet weather spring in driveway #39
We always had good luck with just a good clean grade on bottom. so as to flow, put the pipe in and gravel to what ever level we needed. Then something on top to keep surface dirt from filtering down through. We've used straw, felt paper cut to width, then the last few years I worked, we got surplus filter fabric, that contractors had left over from jobs.
I put a few drains in myself for personal use around my new buildings last fall. I used a top of the line fabric they use under mulch. Supposedly resistant to solar rays for 10-15 years. A 3' wide roll cut in half, was perfect for my 16" trenches.
I'm thinking with that much of a volume of water, any fine stuff will be flushed from the pipe.
I would put a varmint barrier cap on the end. Muskrats love plastic pipe..!!
   / Wet weather spring in driveway #40
Lowes has slotted drain tile with a mesh around it to filter out silt for about $48. This drain tile works very well as we have used it with great success in parking lot with underground water problems
2003 International 9200I (A53317)
2003 International...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
10' CONTAINER (A52706)
2019 GALYEAN...
2015 Chevrolet Tahoe SUV (A59231)
2015 Chevrolet...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
