The gully to pond project
   / The gully to pond project #251
Ron, that is a great point, being able to lower or elevate the water level. Sure would help when maintenance was needed.
The most important advantage after eliminating freeze heave IMO is to be able to easily adjust the freeboard level on the dam.
Earth dams, no matter what soil composition and how well compacted during construction, have a tendency to settle/compact more on their own over time. The part of the dam that has the most fill settles the most. I had to lower my vertical riser one time because of this issue. I measured how much I wanted/needed to cut off while the water was still going over the top edge of the riser. Then during the summer when the water level was a bit lower than the amount I needed to cut off I took and old handsaw to the pipe and cut it off in a couple minutes. No digging involved.:cool:
Getting quick ground cover established on the bare dirt around the pond is the best solution to keeping erosion from getting back into the pond.
It takes years to get a balanced ecosystem in a pond so mucking it out needs to be avoided if possible more than once every 20-30 years.
Fish are pretty tough but leaving their hiding places and nests undisturbed is the best when possible.
Ron
Jim, I did not know the culverts you are using floated.
Don, an empty culvert is just a round boat. If you put an extension and vertical section under water, it has the same lift as a big canoe (a really BIG canoe). Take an empty coffee can turned bottom down and push it straight down into the water for the same effect.
   / The gully to pond project #253
This is more like what Don was referring to as an adjustable riser.
Langston University Aquaculture
Yesterday, I posted photos of my clay highway. Today, I have some photos of my clay mine. I first excavated with the backhoe, but the area is now so big that I can drive the tractor down and fill the bucket with clay while saving the backhoe step. I took pictures of my tractor so you could see the proportions of the mine. I guess I'm a strip miner on a very small scale.:D
   / The gully to pond project #257
good pictures Jinman, looks like you're moving a little clay :D. Can't do anything around here with all the rain and melting snow.
   / The gully to pond project #258
Yesterday, I posted photos of my clay highway. Today, I have some photos of my clay mine. QUOTE]
Wow.. the Google crawler is really keeping close tabs on you. This post was on Google already last night.
So watch what you say, brush your teeth, and smile for your world wide Google audience :D
   / The gully to pond project #259
The key words strip mine? Now the Feds are involved.:D
Mobile toilet with shower (A53424)
Mobile toilet with...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
Metal American Flag Wall Art (A55853)
Metal American...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
