Dump for tractor vs. dump for truck
   / Dump for tractor vs. dump for truck #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Spring is coming and im thinking about this seasons projects. Most of them from ditching to landscaping require moving dirt from A to B. This leads me to dump trailers.
Last year i dug a bunch of ditches, and the evidence is still there is spoils piles around the perimeter of the property.
These must go this spring. I moved a bunch last year, but moving a lot of dirt with the BX sucks. Too small of bites and much time spent in travel. Not to mention increased rutting along the traveled path.
So a dump is the answer.
Currently i have a Deere 17P trailer and while good for grass, its absolutely miserable for dirt (or anything else heavy) because it wont dump completely due to the "tail". When you dump you end up having to shovel 1/2 of the load. Not Deere's best design.
I currently have a bid in on a well used Pronovost P503 off road trailer. There is a thread discussing that here :http://www.tractorbynet.com/forums/attachments/237441-whats-worth-pronovost-p-503hs.html
Other options are a NEW King Cutter XB 4'x6' $2400
or some left over Normand 1920-8 4'x8' for $3000.
Obviously if i miss out on the beat up Pronovost, the Normand is the best deal in an offroad trailer.
Compare that with on road trailers:
Used 5x8 Hawke trailer at $3000. Hawke arent high end and dont really seem to last up here paint wise. 2008 Hawk Dump Trailr - Halifax Cars & Vehicles For Sale - Kijiji Halifax Canada.
Up to
New 6x12 Triple Crown brand (no idea of their quality in person but southern US made trailers generally dont hold up to our climate very well) for $5500 New 6'x12' 10K Dump Trailer - Halifax Cargo, Utility Trailers For Sale - Kijiji Halifax Canada.
And even higher
7x12 geterdumped for $6995 2012 12K DUMP TRAILER/TRAILERS - Halifax Cargo, Utility Trailers For Sale - Kijiji Halifax Canada.
I know that its comparing apples to oranges (sort of) but if i have to buy a new dump trailer, an offroad at $3000 is could get me a used On road. I dont want to pay 6-7K right now for a new onroad trailer.
But if i go On road, would the BX handle it offroad, on hills? It would certainly be harder to manage close to the house and possibly tear up the lawn due to having less floatation. It would also be harder to hook up to for cleanup duty as well.
I always wanted an onroad dump for trips to the dump and the quarry, but if i bought one it would have to be big enough (and have ramps) so i can carry the BX which means a larger trailer that the BX might not be able to handle.
Gahh. Decisions. :mur:
   / Dump for tractor vs. dump for truck #2
The on-road trailer will probably have brakes, which would help if you can make them work with the BX. Will you be loaded downhill and empty uphill, or the opposite?
If I remember right, the BX2360 was rated to tow about 1500 pounds.
Bruce
loaded both ways potentially.
I honestly think that the off road would be the more practical and correct solution.
I think that if i go on road, im going to end up having to use the truck to move which opens up a whole new mess.
1500 Lbs eh? I spoke to the dealer and he said that he has several of the 4x8 off road's out. They are 3000 Lb capacity and he said there is no issue because of the dual wheels and the fact that most of the weight is carried by them. It definitely was something that crossed my mind however.
   / Dump for tractor vs. dump for truck #4
What about changing the tail of your Deere trailer so it dumps correctly?
I would but its plastic. And it has the crappy lever lock to lock the dump, which usually fails when there is a full load on back.
I could raise up the dump by installing MUCH larger tires and improve the locking mechanism, but after all that $$ it would still be a lawn cart.
Hopefully ill win the auction and i wont have to think about this anymore:p
   / Dump for tractor vs. dump for truck #6
I would give serious consideration to that used on highway. You can use it for other things. If you only put as much in it as you would put in the off road you can probably handle it and it will have larger tires than the off road. Just only load it half way! (Do hook up a brake contoller if you have hills though)
Roy
Roy
Hawke doesnt even show that 5x8 anymore so i have no idea what its weight is, but the 6x10 is 2700 lbs, so a guess at the 5x8 would be 2000?
The off road Normand above is only 866 lbs in 4x8. This could be significant with a small tractor such as a BX.
   / Dump for tractor vs. dump for truck #8
I am having similar thoughts about dump trailer acquisition for moving dirt piles around on my land.
Because I am poor, I was leaning more towards something like these:
Country Lawn & Garden equipment, off-road dump trailers, lawn carts and dump wagons.
Does anyone have any direct experience or general predictions about reliability of more lightweight trailers like these, as opposed to the heavy duty all steel ones scooby listed above?
For instance, the 7340 trailer lists a 2000 lb capacity. With the optional hand crank hydraulic dump, it's only $900... so much more affordable. But NOT if it snaps in two as soon as you pull a full 2000 lb load of dirt over rough terrain.
Those country lawn trailers seem to have a decent reputation on here. I dont think one would snap in half with a load on it. But it is made considerably lighter that the ones i posted.
My concern is the wooden deck. You'd have to cover that with something here or the clay mud would never slide. I also wonder if the dump angle is high enough.
   / Dump for tractor vs. dump for truck #10
I have a cart similar to what Deezler posted. The one he posted a link to looks a little better than mine. Its O.K., and it dumps most of the load if you load it correct, maybe a little more toward the back, and than drag it forward a little bit after you dump it. Since I got my BX, I hardly ever use it, but if I had a bigger piece of property I might. For a BX, I would look for a larger trailer, like the OP is looking at. I thought the BX was rated at something close to 2000 lbs for towing.
iDrive TDS-2010H...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
2019 GALYEAN...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
Land Hero 24" Semi Automatic Tire Changer (A59814)
Land Hero 24" Semi...
