diesel fuel additive??????????
   / diesel fuel additive?????????? #31
Schaeffer Diesel Treat 2000. A gallon treats 2000 gallons and I can get it for $40 per gallon. And its proven to work. Been running it for two years with no problems.
+1 on this! Have used this product for 10+ years at truck fueling terminals from Laredo to Detroit with absolutely no problems. Go through 15-20 pallets per year.
   / diesel fuel additive?????????? #32
Sea Foam.:thumbsup:
   / diesel fuel additive?????????? #33
Since this thread got revived after being dead for nearly 6 years, I'll ask a question. How in the world does algae grow in diesel fuel? I'm not denying that it does, but isn't that an awful hostile environment for algae? Does it grow in the fuel or just on the walls of the tank, above the fuel? Very interesting.
   / diesel fuel additive?????????? #34
I think once the fuel seperates and water is in the fuel it grows in the water in the fuel. so the water on the bottom of the tank grow algea, thats where fuel is drawn from so not only do you get water but your filter plug up with the crud that was growing in there.
   / diesel fuel additive?????????? #35
Sulfur is a natural biocide. Since ULSD came about, algae growth occurs even more so than before.
   / diesel fuel additive?????????? #36
Funny, my oil testing house said skip the PS. Based on the UOA, he was right.
How does a used oil analysis show the effect of lubricity on the injectors and the fuel pump?
I've been using PS white since about 1988. I hadn't been tracking the price on it but I don't remember it costing $17 for the 80 oz size. That works out to about 7 cents per gallon of fuel for treatment.
Since I got my 2 recent diesel additions I've become more concerned about the lubricity of my injectors, and finally made the step up to Opti-lube XPD and bought a 5 gallon pail. That works out to 10 cents per gallon of fuel treated.
   / diesel fuel additive?????????? #37
No clue on the fuel pump but you will see higher then normal wear # using PS; at least I did. Stoped using it and went back down; and yes I use the proper rates.
I have better luck with MMO for lubricity issues. I nice gentle cleaner and great UCL.
   / diesel fuel additive?????????? #38
I have summer diesel from 2011 and is fine. I have never see algae issue in diesel, at least for me.
   / diesel fuel additive?????????? #40
From http://rivrdog.typepad.com/files/copy-of-diesel-fuel-additive-version-3.pdf
17) Marvel Mystery Oil
Gas, Oil and Diesel fuel additive (NOT ULSD compliant, may damage
2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
Galvanized Livestock Gates - (5x Gates) (A55218)
Galvanized...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
