3 bottom plow purchase advice
   / 3 bottom plow purchase advice #21
jagyzf said:
I don't know why they would pull harder. I could see having to down size though based on weight, having double everything has to be heavy.
The weight is what was mentioned as to it pulling harder.
Jagyzf,
Thanks for the pictures and the education.
jagyzf,
What does the link actually control? It looks like with the tire down the link is the adjustment for depth control.
   / 3 bottom plow purchase advice #24
jagyzf,
Which link the top link on the 3 pt? Or the linkage that goes to the back wheel?
Which plow are we talking about? I posted a few.
jagzyf,
sorry, I knew which plow I asked about and apparently I must have thought you had ESP..ha.
It was the IH740 and the linkage I was wondering about was the one from the rear of the plow that goes from the tire assembly to the front of the plow
correction...IH710 was the plow in question
An old timer told me once when I was a kid..
"put brain in gear before engaging mouth"
I think today it would likely be...
"put brain in gear before engaging fingers"
JasG,
thanks for link to the oliver plow book,it looks it should answer a ton of questions
   / 3 bottom plow purchase advice #30
Will a 2-3 bottom plow work well for planting food plots?:confused:
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
KEWANCE 200 9' GRADER BLADE (A51243)
KEWANCE 200 9'...
Mini Forks (A50322)
Mini Forks (A50322)
