3 bottom plow purchase advice
   / 3 bottom plow purchase advice #21
jagyzf said:
I don't know why they would pull harder. I could see having to down size though based on weight, having double everything has to be heavy.
The weight is what was mentioned as to it pulling harder.
Jagyzf,
Thanks for the pictures and the education.
jagyzf,
What does the link actually control? It looks like with the tire down the link is the adjustment for depth control.
   / 3 bottom plow purchase advice #24
jagyzf,
Which link the top link on the 3 pt? Or the linkage that goes to the back wheel?
Which plow are we talking about? I posted a few.
jagzyf,
sorry, I knew which plow I asked about and apparently I must have thought you had ESP..ha.
It was the IH740 and the linkage I was wondering about was the one from the rear of the plow that goes from the tire assembly to the front of the plow
correction...IH710 was the plow in question
An old timer told me once when I was a kid..
"put brain in gear before engaging mouth"
I think today it would likely be...
"put brain in gear before engaging fingers"
JasG,
thanks for link to the oliver plow book,it looks it should answer a ton of questions
   / 3 bottom plow purchase advice #30
Will a 2-3 bottom plow work well for planting food plots?:confused:
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
HAMM HD+ 120i SMOOTH DOUBLE DRUM ROLLER (A52705)
HAMM HD+ 120i...
2012 PETERBILT PB348 FUEL & LUBE TRUCK (A54756)
2012 PETERBILT...
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A55787)
2025 GIYI GY-X39F...
